Sticking Caliper
Old Oct 18, 2001 | 12:33 AM
Gimpdiggity's Avatar
Unhappy Sticking Caliper
I just got a 1986 RX-7, and one of the rear caliper's is sticking. The car has just been sitting for about a year, and it runs fine, except for the sticking caliper.
Does anyone know any quick fixes for this?? Your help is greatly appreciated.
Thanks.
Old Oct 18, 2001 | 12:45 AM
PraxRX7's Avatar
hmmm
No quick fix....check the brake rotor for warpage or have it checked, and you will probably have to replace the caliper.
Old Oct 18, 2001 | 12:55 AM
Talking
Darn it.
Oh well, what do I expect for 700 bucks, right???
I guess I'll just have to get a new caliper.
Thanks for the info.
Old Oct 18, 2001 | 11:12 AM
SpeedRacer's Avatar
Formula Mazda Driver
Hey wait....don't do that...Mazdatrix sells rebuild kits for $25 and that will rebuild BOTH rear-calipers. Now you might be thinking, how the hell do you rebuild a caliper? Its is EASY AS HELL. I had no clue until I read through my haynes manual and bought the rebuild kit. Its just a matter of pull out the stuck piston in the caliper, cleaning it up, replacing a few rubber seals, lubing it up and putting the piston back in. And your rear-calipers will be good as new. If the rear-piston is stuck, then the dust boots and seals are probably shot, and the resulting dirt and crud that will be in the caliper might make getting the piston out pretty hard. You have to turn it to get it out. Goto an auto-parts store and ask for a tool for removing calipers. The tool that I have is a little cube, that fits on a socket wrench. Each face of the cube has little ***** on it. You just gotta find which face of the cube has ***** that fit into the little niches on the piston in the caliper. It will make sense once you take a look at the piston and the tool. I actually took some pics of the rebuild. PM me and I will try dig them up for you. They came out pretty blurry though.
Old Oct 18, 2001 | 11:44 AM
SWEET!!!
I'll have to get one of those rebuild kits. That will save me quite a bit of money.
Thanks alot guys.
Most boards that I go to I don't get help like this. You guys are great.
Old Oct 18, 2001 | 01:57 PM
SpeedRacer's Avatar
oops...I meant to say, ask for a tool for removing the piston from a caliper. Describe to them that it is a cube and each face on it has little nubs sticking out that are supposed to fit in the niches of the piston. There are different types of piston removing tools for different types of pistons and calipers, so this will narrow it down for them.
Glad I could be of service. I almost went out and bought new rear-calipers too, until somebody told me about rebuilding the calipers.
Vartok
Sep 24, 2015 02:20 PM
