Thoughts on shock valving and winter
Old Jan 25, 2004 | 01:15 AM
peejay's Avatar
Old [Sch|F]ool
Just came back from a short drive to make sure the car handles subzero temps. Yes friends, the mercury plunged down to -3 F (even more depressing if you think in Metric) in Cleveland. Fortunately, that's about as cold as it ever gets here.
The stock Mazda shocks are set up to be rebound-heavy. That is, the rebound (extension) damping is stiffer than the jounce (compression) damping. This has various benefits for handling purposes, which are beyond the scope of this post.
When it gets cold, the fluid in the shock thickens. It's just oil, after all.
When it gets down to -3, it apparently thickens to the point where it's a barely flowable jelly ooze.
It seems to move somewhat under compression. Not much. But the stiff rebound valving doesn't want to let fluid pass through at *all*.
Now picture a lone, salt-coated GSL driving down the lumpy Cleveland roads. Hobbyhorsing over every bump, since most of the suspension is now the tires, thanks to the gelled shock fluid. And with every bump, the car gets a little lower, since the shocks won't rebound. After about 1/4 mile the car was riding down on the bumpstops. Took 20 minutes for the fluid to heat up enough for the suspension to start moving.
Happy winter, y'all...
Old Jan 25, 2004 | 01:28 AM
faye x7's Avatar
brilliantly stupid
Yeah, we've been getting some nice -20 degree temps here. Windchill that is....but still damn cold.
I've noticed my car rides very different in the early morning or late nights.
Old Jan 25, 2004 | 04:13 AM
Jeff20B's Avatar
Lapping = Fapping
A low rider.
Old Jan 25, 2004 | 06:52 AM
KehoeAutomotive's Avatar
The US Army Cold Winter Testing Facility in Greenland had to close once because of poor weather.
The temp reached -45degrees!!!
Wehn it get cold enough, GEAR OIL FREEZES!
Old Jan 31, 2004 | 03:18 PM
peejay's Avatar
Old [Sch|F]ool
Yah I remember my autos teacher telling me about where it gets really cold, the gear oil in the rearend turns to stiff grease and it burns up the gears and bearings because they just ride in a trough dug through the sludge instead of having flowing liquid oil. Fun stuff, and a great argument for synthetics.
Old Jan 31, 2004 | 09:24 PM
Rx7carl's Avatar
Airflow is my life
Drive it hard to heat up teh fluid. "Officer, I was just trying to heat up my shock oil so they would work right."
Old Feb 1, 2004 | 04:42 AM
peejay's Avatar
Old [Sch|F]ool
That doesn't work when the tires are as grippy as cast iron, and the engine needs careful nursing when you apply throttle lest it run so lean it just *dies* (even at 3500rpm!) and you can't see out the windshield because the engine *still* isn't warm enough to generate any useful heat...
Ah, I love winter! I don't know how you guys in the warmer climes can deal with your winters.
- Pete (It's 50 degrees in my bedroom! Whee!)
Old Feb 1, 2004 | 05:35 AM
Jeff20B's Avatar
Lapping = Fapping
Don't breath on anything too enthusiastically. You may not be able to read your monitor.
Old Feb 1, 2004 | 11:54 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
You could be driving your seven in minus 40 Celsius weather...
Let's see, what stops working at that temp?
-Brakes: My brakes cease boosting at around -35 or so, all the booster does is make a 'SQUOOOO!' sound, followed closely by me panicking because I now have manual brakes.
-Suspension: My shocks get so cold that they simply cease working. My ride height doesn't alter rather it's simply like driving a buckboard.
-Heat: My heater stops putting out hot air and instead decides to blow cold or at best tepid air.
My car WILL start though, which is better than most.
Old Feb 1, 2004 | 12:05 PM
mar3's Avatar
Administrator
Thank God I live in Texas. I've lived on both coasts and in Kirkland, Washington....but always come back to the Metroplex...-3 degrees? No freakin' thanks!!
Old Feb 1, 2004 | 12:10 PM
peejay's Avatar
Old [Sch|F]ool
Yah. I am suprised the poor bugger runs at all, actually. THIS close to putting the MSD in, but that would require bumming heated garage space for a few hours.
Had the vacuum booster freeze up in my T-bird. Not even manual brakes, the brake pedal was just a footrest. Hit the retaining wall in the parking lot at work at about 10mph. Good times.
I told you guys about how I managed to freeze my cooling system, split the radiator, and not find out until AFTER overheating the engine, right? (This being on a day I interviewed for a job) Engine's fine, and there's a shroudless '80 radiator where the Mongoid '85 radiator used to be. I figured the smaller radiator and poorer shroud would enhance warmup time. Nope. I consistently start to get good heat after 9 1/2 miles of my 10 mile trip to work in the morning. Gotta drive with the windows open to keep the windshield from fogging up, too...
- Pete (Is that -40C or -40F? )
Old Feb 1, 2004 | 12:15 PM
g prime's Avatar
So will this warm up with time, I think my car is having that problem, through havn't driven it yet when it's like this.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Carpe_Diem_7
32
Mar 29, 2016 03:28 PM
Tem120
Sep 7, 2015 09:53 AM
