Common driveshaft ?
Old Jan 24, 2004 | 06:22 PM
lpsgslse's Avatar
Common driveshaft ?
Hi all! Is the driveshaft from a GSL-SE different from all the Non-GSL-SE driveshaft? 13b or 12a? Or is the driveshaft the same across the board? Thanks all.
Old Jan 24, 2004 | 06:44 PM
peejay's Avatar
Old [Sch|F]ool
Driveshaft is the same for all '83-85 manual transmission and '83 automatic.
The '84-85 automatic driveshaft is different.
Prior to that, driveshaft is the same '79-82 manual and automatic.
Steve Shulz's Avatar
Im pretty sure (90%) that 79-82 are the same. 83 through 85 are all the same including GSL-SE. Automatics are about 2.5 shorter than standard trans. They are all the same length (expect for auto trans) through all the years, 83-85 have non replaceable u-joints and a bigger pinion (diff) flange. PJ posted right before I did and didnt see it. I wasnt aware of the 83 auto being the same.
Hank
Oct 1, 2015 07:34 AM
series1rx7
Sep 27, 2015 05:46 PM
