Brembo, Powerslot, or stock rotors?
Old Jan 19, 2004 | 04:57 PM
SpeedracerRX7's Avatar
Question Brembo, Powerslot, or stock rotors?
I know a lot of people are going to say search but I tried and it wasn't working.
I am going to upgrade my rotors and here are my criteria. 60% Performance, 20% Practicality(Cost Efficiency/Reliablity), 20% Looks. I autocross some but it is mostly a daily driver.
Ok RX7Store.net has individual slotted rotors for $120 each and yet I can get their slotted and cross drilled for $90 a piece. I have found Power Slots (Slotted) for $105 a piece and free shipping. All of these options seem feesible but my question is about rotor reliablity. I have heard that cross drilled can crack between the holes and thus create a weakened rotor. My question is why would their cross drilled and slotted rotors cost $30 less per rotor than either the slotted or cross drilled when it seems like double the work to get done? Which one would you go with? The stock ones are only $60 or so a piece but I really like the looks of the slotted. Opinions please.
Old Jan 19, 2004 | 05:08 PM
Mahjik's Avatar
Mr. Links
http://turboimport.com/catalog/rx7.htm
Old Jan 19, 2004 | 05:12 PM
93BlackFD's Avatar
built my own engine
gotham racing sells some very nice nickle plated kits
Old Jan 19, 2004 | 05:27 PM
rynberg's Avatar
Drilled will likely hold up just fine for street use or typical auto-x, it's road track that will make them crack. That said, they will probably have a shorter life span than non-drilled.
None of these rotors will be an "upgrade" over stock, consider them to be stock replacements. So, get whatever brand matches your personal looks/price ratio.
Old Jan 19, 2004 | 05:41 PM
Fumanchu's Avatar
Belligerent Security
I was thinking about getting my brakes there. Have you actually gotten them from there Mahjik??
Old Jan 19, 2004 | 05:51 PM
widebody2's Avatar
addicted to lounge
I got the brembos off ebay 3 years ago. I honestly don't remember feeling any braking difference but they have held up fine and look nice. They were very cheep too.xdrilled and slotted
Old Jan 19, 2004 | 05:55 PM
Mahjik's Avatar
Mr. Links
Not yet, but I will be getting them probably in the spring (I have a few other things to take care of first).
For those looking for standard rotors:
http://www.alloemautoparts.com/
About $50 per rotor...
Old Jan 19, 2004 | 07:49 PM
Svelte_7's Avatar
Back on the road again!
I just ordered the turboimport kit (rotors, pads, ss lines) - but they are on backorder for 7-10 days.
Old Jan 21, 2004 | 04:09 PM
BlackRX7Turbo's Avatar
I know someone that bought the brembo blanks (i.e. no cross drilling or slotting) and said he just uses them that way and he feels that slotting/xdrilling just invites the chance to crack... anyone agree with this?
and, if you're saying that non-drilled/slotted is no better than going OEM, are there particular brands that should be stayed away from (e.g. buy from alloemautoparts, but not from JC Whitney)?
Old Jan 21, 2004 | 08:44 PM
Mahjik's Avatar
Mr. Links
For street application, it really doesn't matter. Just whatever you think looks nice.
For track application (road racing), drilled rotors have been known to crack which is why they are not recommended. I have yet to hear of anyone having problems with slotted and they seem to be the preferred choice of the track guys around me.
Old Jan 24, 2004 | 12:59 AM
Carl Byck's Avatar
Mad Man
I like the slotted, they wear the pads a tiny bitfaster, but if you overcook your brakes they recover alot faster. Carl(for the track)
Old Feb 20, 2004 | 12:55 AM
nyc_scorpio's Avatar
R.I.P. Monte Negro FD
hey guy, i got sloted / cross drilled brembos from ebay for my 88 turbo for 249.00 all 4 with shipping... check it out.
Old Feb 20, 2004 | 08:07 PM
rotary-tt's Avatar
2 babies - no back seats
The stock rotors have split internal fins and I believe they are lighter for less unsprung weight. Cryo treat the stockers and you're good unless you track alot
Old Feb 20, 2004 | 09:34 PM
what if you cryo treat the cross drill/slotted? would that be better?
Old Feb 21, 2004 | 11:44 AM
wiblergt's Avatar
when you are in the middle of a 90-0 stop, and your brakes feel like they start to "slide" , or if you feel you have to press harder... you are SUPERHEATING you rotors.
if you do this often, like every time you drive your 7, you may just want to stick with slotted.
most people don't drive their cars like that. if this is your situation, i'd go with X-drilled/slotted.
they look sweet!!
bw
Old Feb 21, 2004 | 01:23 PM
Carl Byck's Avatar
Mad Man
Cryo will slow wear, not prevent cracking do to drilling. I Cryo treat my race rotors, it's like ~35.00 a piece, and seems to help. Pads are kley here, I would use carbotech XP9s. Carl
cristoDathird
28
May 30, 2019 08:47 PM
