Power mirror problem on SE
Old Jan 19, 2004 | 09:32 AM
riofrio's Avatar
This IS a tasty burger!
Since just recently, my mirrors can only go down and right with my switch. The up and left keys get no response at all. I'm guessing it's just a bad connection at the switch... is there an easy way to pull that switch out?
Old Jan 19, 2004 | 09:40 AM
anthrax's Avatar
Heck Yes!
If you can get the switch out, and it is not sealed try some contact cleaner.
I had problems with the pasenger side miror on my '85 GSL. I took the miror off one day, unpluged the miror form its plug and pluged it back in. The miror worked great after that.
So any way try that and see if your problem goes away. Other wise try contac cleaner on the switch.
good luck
anthrax
Old Jan 19, 2004 | 09:58 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Ya, just pull the bottom interior peice and pop the switch out from the back and check it. if it doesn't work I can sell you one of mine that I just took out of my recently parted GSL-SE
Old Jan 19, 2004 | 11:58 AM
MarkPerez's Avatar
Tennis, anyone
It's either your switch or your mirror(s) theses cars
always develope some sort electrical connection problems try cleaning contacts.
Old Jan 19, 2004 | 08:43 PM
BigJim's Avatar
trainwreck
are your mirror motors obnoxiously loud? mine is
Old Jan 20, 2004 | 10:35 AM
riofrio's Avatar
Well, I tried that. For one, I couldn't get the bottom interior piece to come out more than half an inch (other connectors/controllers keep it in place). And secondly, I tried popping the switch out from the back, but it feels stuck in there. Do I just need to pull harder??
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
