throttle body modification???
Old Oct 16, 2001 | 01:22 PM
rotaryfreq's Avatar
Newbie
has anyone here tried removing the double flaps , thermo-wax , and dashpot assembly from a non -turbo rx-7? have any luck with it , problems?? i disconnected the linkage to mine , and wired the double flaps wide open. seemed to free up some low end and midrange torque. makes me wonder how much better it could be if i completly removed the assembly , filled the holes left behind with jb weld , and polished the throttle body bores.
Old Oct 16, 2001 | 06:43 PM
HAILERS's Avatar
HAILERS
Try this http://www.k2rd.com/FC3S/HOWTO/TBM/tbm.html this site should be bookmarked.
Old Oct 16, 2001 | 10:43 PM
Ryde _Or_Die's Avatar
What kind of gaims do you see with this mod? Any downfalls? Thanks.
Old Oct 16, 2001 | 11:52 PM
Juan's Avatar
Im a tall midget.
i wish that site would have gotten into detail about the coolant line that comes out of the block. Any have any detailed info on the coolant line?
Old Oct 17, 2001 | 03:21 AM
NathanRX7's Avatar
I just hooked my 2 coolant lines together after doing the throttle body mod. The only downside (if you call it one) to this mod is that you have to manually warm the car up. They don't like to idle at 750 RPM when cold. Also, I don't think there's any way to keep the cruise control working after removing that stuff either, so I removed that, too. Weight reduction, right? Good luck. Let me know if you have any questions. My screen name on AIM is NathanRX7.
Old Oct 17, 2001 | 11:36 AM
Well my car idles at like 1100 or 1200 after it is warm. I never had my car idle below 1000.
Old Oct 17, 2001 | 04:13 PM
SpeedRacer's Avatar
Formula Mazda Driver
Downsides - a little ruffer when letting off the throttle or getting on it.
Upsides - Better throttle response, weight reduction, more air flow(maybe a TAD more boost for turbo owners), and it makes removing the throttle body MUCH easier.
