junk motor?
Old Jan 13, 2004 | 02:19 PM
rotorysuzuki's Avatar
the rxzero
junk motor?
I just picked up another 12a and 2 tranys from an 84 I did a compression check on it and got very little in the front chamber like under 30 and in the back rotor alittle more like 40 the guy who I got it from said he parked it because he didnt have spark but it didnt smoke it has sat for maybe 10 years but it spins fine is there anything I can do or should I just rip it apart and use it for decoration on my garage wall or is it worth anything it has all smog on it
Old Jan 13, 2004 | 02:28 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
if you can get it on a stand and get a starter on it, you can try the ATF trick, then use the starter to crank it at bit.
if it has not been started in 10 years it prolly has a lot of gunk built up.
if not and you want to do a rebuild, just start riping it apart so see if there is any scaring on the side walls.
Old Jan 13, 2004 | 02:34 PM
vipernicus42's Avatar
Rotoholic Moderookie
Get the two 13b rebuild videos that are available and a Heynes manual. Watch both videos, read the manual, and dig right in I'd say
Or just get it rebuilt
Jon
Old Jan 13, 2004 | 02:55 PM
the rxzero
who has the best price on a rebuild kit
Old Jan 13, 2004 | 03:48 PM
Steve Shulz's Avatar
If you have the manual youll be fine, videos are just gravy to what the Haynes already has.
The1Sun
Sep 18, 2015 12:34 AM
The1Sun
Sep 7, 2015 10:21 PM
doritoloco
Sep 5, 2015 12:41 PM
