BASE stock stereo question......
Old Jan 13, 2004 | 12:12 AM
EviLPeNeviL's Avatar
Can't live without boost.
So then I have a base FD without all the extra Bose crap. I'm going to be replacing the HU with an aftermarket one. Now I heard that the stock HU is connected to some sort of stock amp?
Does the replacement sound as easy as it looks? Just buy a new HU and plug it into the dash or do I need a new aftermarket amp to run it.
And also I will be getting new front and rear speakers. From my experience and knowledge I could just take out everything and hook up new front/rear speakers to a new HU......
-Dan
Old Jan 13, 2004 | 01:58 AM
Okay so then like I really need some quick answers to this one, getting stereo within the next few days....................
-Dan
Old Jan 13, 2004 | 02:44 AM
i have the stock bose but a diff HU, stock amp. i got mine hardwired w. out a harness too. ghetto i know
Old Jan 13, 2004 | 11:06 AM
Is it just an easy plug n play with the stock amp and an aftermarket HU then?
-Dan
Old Jan 13, 2004 | 11:26 AM
rynberg's Avatar
Dan, you should be able to hook up new speakers to existing wiring.
The new head-unit will not just plug in. You will have to redo the wiring harness unless you just want to purchase a harness adapter (like from Crutchfield). With the adapter, it should be plug-and-play.
The only amp the non-Bose system has is for the center-channel speaker. It is already wired in, so don't worry about it.
Old Jan 13, 2004 | 01:02 PM
Thanks Tyler...... Yeah I know that there is the separate wiring harness to be able to plug n play properly. I need to kick up the music finally!!
-Dan
Skeese
65
Mar 28, 2017 03:30 PM
