master clutch cylinder
Old Jan 12, 2004 | 09:31 PM
red_blast's Avatar
S.F.W.C. Liberator
my slave clutch cylider is dying on me. and i am going to replace the slave and master cylinder as well as the hose but.... i have no money for parts so i have to wait until thursday...payday... to get the parts... my question is.... how bad am i chancing it by waiting to replace this stuff. is it going to die on me any second, any day, or in a week?
i am totally freaking out.
Old Jan 12, 2004 | 09:57 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
If it's working right now, it will probably work alright until you're able to replace the necessary parts. It's good that you're replacing or rebuilding both Master and Slave cylinder together, since the rubber parts that make the hydraulic system work wear out at about the same time.
You may find that your clutch pedal gets stuck all the way down, which can be remedied by pulling the pedal back up manually. This is due to the bleed port getting obstructed and not allowing more fluid to be drawn into the master cylinder piston when it's evacuated by draining out of the slave cylinder seals.
I have had good luck finding complete units (not rebuild kits) for both master and slave cylinders at BAP. I don't know if Autozone or PEP Boys will have it, but worth a try. The BAP parts are not Mazda factory, but fit and function just the same - the design is used in many different kinds of cars, so compatibility of the mounting holes is the largest issue next to swept volume.
Good luck, the job should only take you a few hours if you build it up and bench bleed the master cylinder prior to assembly.
Old Jan 12, 2004 | 10:06 PM
red_blast's Avatar
S.F.W.C. Liberator
i am just waiting to be in the middle of traffic and my clutch becomes stuck to the floor. and i have to do a second gear start. :-/ i just know thats whats gonna happen. hah.
and i am gonna go to advanced auto parts and get prices for the parts and i figure once i get the parts....replacing everything should take about 2 hours. and thanks for the advice. i appreciate it.
rhinor61's Avatar
I always thought that is what credit cards are for. Need your parts now but not paid until next week.....
My .02¢
John
Old Jan 12, 2004 | 10:07 PM
red_blast's Avatar
S.F.W.C. Liberator
yeah....credit cards are great.... when they aren't maxed out. HAHA! see my problem.
Evan Kurtz
Sep 13, 2015 08:40 PM
