Welding UniBody Construction for Stiffer Frame..
Old Jan 11, 2004 | 10:07 PM
JunpoweR's Avatar
GTUs WHORE!
I am about to take on this Project of stiffening my FC3S GTUs..From what i have learned i think i am gonna spot weld in between every stock weld.Also probably Weld in a rear strut bar.One solid piece of 1.5 inch thick Aluminum Bar right next to the shock towers...Rear Autopower Roll cage Welded in and some tack welds to the Frame and Seam weld some areas..Any help and information would be helpful..
Anyone done this before on their FC??
oh i have a ARC welder and gonna have a MIG kit soon for it..Is this the Welder i should be using?
Old Jan 11, 2004 | 10:24 PM
bigmack000's Avatar
Rotor DEMON !
umm migth need a tig for aluminum. notto sure is mig can do that.
joel
Old Jan 11, 2004 | 10:33 PM
JunpoweR's Avatar
GTUs WHORE!
Well i learned Basicaly MIG welding is performed
Just like ARC welding..
But uses a sheilding gas to Keep Oxygen away from the heated surface.I guess it makes cleaner welds.(less splatter mabey)?
ARC welding uses a FLUX core wire without sheilding gas..
Oh yea Q's
How would i weld aluminum to the steel on the frame any questions??
I think mabey a certian Flux would work??or should i MIG weld it?
Anybody?
Old Jan 12, 2004 | 01:25 AM
skunks's Avatar
I'm a CF and poop smith
you need a tig to weld chrome moly and aluminum. in anycase, if i can get off work early next week saterday i can watch my friend kell seam weld his FC, he is doing the entire thing. ill try to take some pics of it and post them
Old Jan 12, 2004 | 10:05 AM
JunpoweR's Avatar
GTUs WHORE!
Cool!!!
Sounds like Fun!! =)
TIG huh..
Well i guess??
What if i just used a 1" thick Steel Rod instead,
Can i MIG or ARC weld it??
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Turblown
Sep 30, 2015 05:58 PM
