wheel bearing
Old Jan 11, 2004 | 04:52 PM
red_blast's Avatar
S.F.W.C. Liberator
Question wheel berring
how do i replace a wheel bering? and how difficult is it to do yourself?
Old Jan 11, 2004 | 04:59 PM
Felix Wankel's Avatar
Super Newbie
front or rear?
Old Jan 11, 2004 | 05:07 PM
specRX7_22's Avatar
front is easy, sorta... but if your changing the fronts, you might as well just chance the rotors if there half bad.while your in there. just my opinion.
Old Jan 11, 2004 | 05:10 PM
inittab's Avatar
I read your email
Welcome to the forum!
Replacing the fronts is pretty easy but the rears are rather difficult IMO. Get yourself a Haynes manual (I see 'em cheap on eBay all the time) and take a look at the wheel bearing section. I do most everything on my RX-7 including front end alignments but the wheel bearings is something I would have done by a professional that has all the proper tools at his disposal.
Old Jan 11, 2004 | 05:45 PM
Dom's Avatar
Dom
callin' tokyo
The Factory Service Manual can be downloaded here:
http://www.wankel.net/~krwright/cars/rx7/85_manual.html
- see section 9 -
Take wheel off
Remove two screws off brake caliper
Hang brake caliper on coil spring (with coat hanger)
Remove dust cover
Remove cotter pin and nut
Pull rotor off
Replace bearings and seal
Reassemble
Do other side
Old Jan 11, 2004 | 05:58 PM
Steve Shulz's Avatar
Yep, pretty easy (fronts). I took my rears to a machine shop to get off and pres new ones on. After removing the axles first!
Old Jan 11, 2004 | 06:13 PM
red_blast's Avatar
S.F.W.C. Liberator
thanks
thanks guys. i'll give it a try. hopefully i can do it right. haha
