First Gen Tool kit........
Old Jan 11, 2004 | 03:09 PM
jimtesla's Avatar
Hey
what should every girst gen car carry on board for when
problems strike out on the road...?
Sizes of wrenches etc......
Old Jan 11, 2004 | 03:44 PM
rhinor61's Avatar
I carry in a canvas tool bag the following:
Flash light
Combo wrenches, 7,8,10,12,14,15,17 (10-12, 13-14 combo open end.
3/8 ratchet, short extension
3/8 sockets, 10,12,14,17,19, spark plug
Stubby phillips screwdriver
6-1 screw driver
Flat screwdrivers: small, med, big
Phillips screwdriver: small, Med, big
wire cutter/strippers
black electrical tape
Channel lock pliers
slip joint pliers
razor knife
12v Test light.
small spray can of WD-40
Matches/cig lighter
Misc electrical connectors,
small about of wires (14g, 12g, 10g)
Spare fuse
Spare fuse links
2-spare ignitors
Nylon ty-raps
4 used spark plugs
cap
rotor
fuel filter
Put all this in the passenger side storage box.
Old Jan 11, 2004 | 03:45 PM
wwilliam54's Avatar
it WILL run
fix a flat and a tow strap
Old Jan 11, 2004 | 04:03 PM
Steve Shulz's Avatar
Same as above!
Old Jan 11, 2004 | 04:24 PM
Keaponlaffen's Avatar
Man, Rhinor, with all those tools you could pretty much do a rebuild if you had to....
Old Jan 11, 2004 | 04:52 PM
1984special's Avatar
So little time and money
AAA card. Tools (and spare + jack for that matter) too heavy!
Old Jan 11, 2004 | 06:37 PM
1rx7owner's Avatar
Lifes a garden dig it.
I have a flathead screwdriver a 10mm wrench and a cresent wrench.
Old Jan 11, 2004 | 06:57 PM
7addict's Avatar
Talking
You know all those things are important, but I also added a for sale sign which I put up a couple of times in frustration. I always wondered what would have happened if I carried a stick of dynomite!
Old Jan 11, 2004 | 07:01 PM
Sk8r_dude's Avatar
Zoom - Zoom...
definatly need the wd-40espeacially with a carb...
Old Jan 11, 2004 | 07:22 PM
Jeff20B's Avatar
Lapping = Fapping
Spare alt belt
Spare spark plug wires
bottle of oil
Old Jan 11, 2004 | 08:08 PM
AAA card
Old Jan 11, 2004 | 08:15 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
Originally posted by Rutnick
AAA card
yes the one with unlimited tow milage.
Old Jan 11, 2004 | 08:24 PM
mazdaverx713b's Avatar
Have RX-7, will restore
Flash light
6-1 screw driver
Channel lock pliers
slip joint pliers
razor knife
12v Test light.
Matches/cig lighter
Spare fuse
Spare fuse links
2-spare ignitors
Nylon ty-raps
4 used spark plugs
cap
rotor
fuel filter
whats not to love about that!? perfect. i usually carry a tool set (craftsman wratchets and wrenches), a couple screwdrivers, pliers, 14ga. wire, cutters, gloves, a warm hat, and a plastic drop cloth.
Old Jan 11, 2004 | 08:26 PM
esoto66's Avatar
..........lol
Old Jan 11, 2004 | 08:27 PM
lets not forget that fire extinguisher! i carry one. i know a lot of guys here carry them! that can be a very useful tool!!!
Old Jan 11, 2004 | 09:00 PM
matthewpims's Avatar
I carry a 3/8's drive SW and spark plug socket, 2 qts of oil, one full thing of antifreeze, some brake fluid, a flat head screwdriver and some pliers, oh and an emergency qrt of mmo!
Old Jan 11, 2004 | 09:38 PM
Rotofire's Avatar
Yea, I'm working on it...
i carry a 60 peice craftsman tool kit and a fith of beam
P.S. to all you cops out there, that last one was a joke...please don't pull me over.
Old Jan 11, 2004 | 09:44 PM
indeed...AAA card with unlimited tow mileage and a cellular phone. Don't want to weigh the car down with other stuff.
I got one of the smallest cellular phones made. I got it just for my car
Old Jan 11, 2004 | 09:56 PM
hehehe.... a few of these....
Old Jan 11, 2004 | 10:25 PM
82transam's Avatar
Never Follow
qt of oil, qt of brake fluid, cresent wrench, phillips and flathead screwdriver, stock jack + spare, and a cig lighter powered air pump. I probably should carry more, but **** it, the bin isn't big enough and my amp is in the other
Old Jan 11, 2004 | 10:32 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
Bin's only carry the necessary fluids (keep in mind, this is AZ desert and water is hard to find),
gallon of antifreeze
gallon of water
brake fluid
power steering fluid (yes, it's an SE)
2 quarts of oil
small bag of chips
In the rear hatch area, underneath my Mariah hatch, is a small, laundry-type basket that contains the following (and I'm not kidding here...)
Spare radiator hoses, upper and lower
4 feet of heater hose, various sizes
hose clamps, all sizes
jumper cables
box cutter
spare belts, all of 'em
clean T-shirt, gloves
flashlight
toolkit (containing most of what others carry)
Fuses, lighter, anything small that gets thrown in that might prove useful.
All this stuff is due to past experiences with an 80LS and this 84SE, and any number of other instances where a pinhole leak in something left me stranded and low on fluids. It may seem like overkill, but when I'm working under the car, and notice that my lower radiator hose is leaking - I replace it. Next trip to the auto parts store gets me my 'spare' back in the hatch.
I was a boyscout growing up and learned a thing or two. "Be prepared."
Old Jan 12, 2004 | 01:53 AM
Lotus00's Avatar
I have been driving my 82 for 3 years now, and it has never left me stranded on the side of the road. (it has done some limping home though)
the only tool a have in my car is a tire pressure gauge.
Old Jan 12, 2004 | 02:13 AM
Directfreak's Avatar
I am a Jeeper Now.
cell phone.
Old Jan 12, 2004 | 04:47 AM
timmya2's Avatar
a *****
Old Jan 12, 2004 | 11:27 AM
Ludicrous's Avatar
Drive it like u stole it
Cell phone & AAA card.
