2 quick questions
Old Jan 9, 2004 | 10:09 PM
rmayton's Avatar
2 quick questions
does anyone have a pic of the upper bolt beside the dowel pin, i was told a while back to tighten it to 100 lbs, so i could stop my oil leak! they said to remove the trans and clutch and tighten this 1 bolt and it should stop the leak without hurting anything. does this sound reasonable.
On a different note, why is not posible to make a header from alum. ?
i thought that it would dissipate heat quickly?
Old Jan 9, 2004 | 10:53 PM
BigJim's Avatar
trainwreck
I think aluminum will melt, or deform before it can dissipate that heat. 2000 degrees is alot of heat to get rid of
Old Jan 10, 2004 | 02:29 AM
rhinor61's Avatar
Stop the oil leak by over tightening a bolt?
Hmmm
The reason its leaking is because of a bad o-ring, motor rebuild.
You shouldn't make any exhaust pieces out of aluminum, it would melt or crack before it melted.
Where do you find this stuff?
John
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
