Turbo FB: Which turbo to run?
Old Jan 9, 2004 | 11:12 AM
brianmcd's Avatar
Hey. I've got some plans for a blow through carb 12 setup, but I'm trying to figure out which turbo to run. I was thinking s5 TII turbo maybe, how much can I source one for? I need something somewhat cost effective, but I want to get power and responsiveness. I'd like it to spool up pretty quickly, and I'm thinking 14 psi or so on the s5 TII turbo if I get that. Is the TII turbo a good choice? Is 14 psi too much? How much can a 12a with hardened stationary gears but stock rotors and compression (doing a rebuild + doing stationary gears and streetport) take? Thanks a lot.
~brian
EDIT: Tried to delete this post but it won't let me. I found all my info I need in another thread, so I'll post there. Mods please delete this tread, thanks.
Old Jan 9, 2004 | 02:02 PM
coldy13's Avatar
Yeah, shutup kid.
The TII turbo is a great size for it, it will spool quick. The stock 12a won't take more than 16psi before it starts blowing oil out the dowel pins. But 14psi will be fine. I usually keep mine around 12psi as after 12psi the TII turbo starts getting very inefficient and producing much more heat.
Old Jan 9, 2004 | 06:28 PM
Stoops417's Avatar
wow, thank you very much! i have been looking for just this info!
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
