Would New Fuel Pump Make Me Run Rich?
Old Jan 8, 2004 | 08:58 PM
Ocelot's Avatar
Y00s a h000
Would getting a Walbro 255 installed before I did most of my modification make me run too rich? All I have now is intake, boost gauge, and FCD, and a bunch of other crap that doesn't have to do with performance or monitoring it. Anyways, I plan on getting a downpipe and either going for some sort of straight through setup, or getting a high flow cat. I was just wondering if getting the Walbro before doing this would make it run too rich or anything.
Old Jan 8, 2004 | 09:18 PM
Ocelot's Avatar
Y00s a h000
Ok people, it may be a stupid question, but its a damn easy one, just take two seconds to type "yes" or "no" lol
Old Jan 8, 2004 | 09:24 PM
xfeastonarsex's Avatar
fire from MY tailpipe!
I dont think it would, unless it increased the pressure.. .then again I could be wrong. The reason I say this is because if the injectos only open for certian periods of time an increase in pressure would force more fuel out. If It just increased the flow I would not think it would. Someoen correct me if im wrong on this.
Old Jan 8, 2004 | 09:26 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
I am almost positive the answer is yes. You can always just do a rewire for now and upgrade the pump later.
Old Jan 8, 2004 | 09:35 PM
Ocelot's Avatar
Y00s a h000
Reason i'm asking is because everyone was telling me go for the Walbro 255 as a safety mod before doing anything else, but I didn't want to put it in ahead of time and all and have it make me run rich. If I installed it at the time I put my exhaust mods in, would I be fine?
Old Jan 8, 2004 | 09:47 PM
Well you would run alittle richer I suppose. Not so much that it would do any harm. What mods do you have now?
Old Jan 8, 2004 | 09:48 PM
Whats the psi of the walbro?
Old Jan 8, 2004 | 09:56 PM
Ocelot's Avatar
Y00s a h000
Says "up to 90 psi". Also, my mods so far are only an A'pexi intake, but i'm going to get a DP and either go for straight through exhaust with presilencer or high flow cat. Possibly ported wastegate of necessary.
Old Jan 8, 2004 | 09:58 PM
Port your wastegate whenever you have a chance. Right now I have a corksport 3inch downpipe to a bonez high flow cat and stock catback with stock intake. On a 4th gear WOT pull I creep to .7 bar= about 11 psi. I think it would have climbed higher if I kept my foot full throttle but I left off once boost built up.
Old Jan 9, 2004 | 07:26 AM
imloggedin's Avatar
i have exaust and intake and im running alot richer with just a rewire.. im guessing that with a walbro youd see it pretty rich.
Old Jan 9, 2004 | 10:21 AM
Aaron Cake's Avatar
Engine, Not Motor
Yes.
Old Jan 9, 2004 | 10:47 AM
West TX RX-7's Avatar
Da Monee Pit
No, the pump doesn't make you run rich but it can make you run lean. Your injectors and cycle on them is what determines how rich or lean it runs. The pump is just how much it CAN flow when needed or CANNOT flow (ie leaning out). I'd rather run rich anyway though but the answer is no, just a fuel pump won't make it run rich. I'd recommend that as one of the first upgrades you do though. Especially if you have a better flowing intake and exhaust.
Old Jan 9, 2004 | 10:52 AM
Aaron Cake's Avatar
Engine, Not Motor
You're confused. The Walboro will make the car run rich because it will overwhelm the stock pressure regulator, thus increasing ruel rail pressure.
Old Jan 9, 2004 | 10:56 AM
igottafc's Avatar
RX7less **(
would you need a new FPR if you wanted to install a higher flow pump or can you just run it on the stock fpr?
Old Jan 9, 2004 | 10:57 AM
Slacker7's Avatar
It will make the car run "significantly" richer.
Old Jan 9, 2004 | 11:03 AM
Aaron Cake's Avatar
Engine, Not Motor
You could run an aftermarket FPR, or an S-AFC (I prefer the latter, or a combination of the two).
Old Jan 9, 2004 | 11:49 AM
Da Monee Pit
Ahhhh I C. I didn't take into account the stock regulator couldn't handle an increase in pressure to it. Good to know!
Old Jan 9, 2004 | 01:50 PM
Ocelot's Avatar
Y00s a h000
Hmm...so if all I was getting was some sort of downpipe/high flow cat, or just straight through w/presilencer and such, would I really need an upgraded pump? Like EVERYONE was saying upgrade the pump, but nobody mentioned any of this other crap. What about installing an FD pump?
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
