vibrations
Old Jan 8, 2004 | 04:57 PM
vibrations
My car around 50mph will vibrate slighty while crusing ,but when I step on the gas itget worse untill i hit 65mph or so and stays away untill 80mph and up. The tires are brand new less than 500 miles. Any Help appreciated.
Old Jan 8, 2004 | 05:10 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Well your probably running way lean if your getting 50 miles per gallon
In any case check your drive shaft-u joints. I had my old drive shaft go back on me.
Old Jan 8, 2004 | 05:12 PM
SureShot's Avatar
Seduced by the DARK SIDE
Do you feel it in the shift or the steering wheel?
Old Jan 8, 2004 | 05:13 PM
oops not mpg ---- mph minor difference right
Old Jan 8, 2004 | 05:16 PM
I feel it in the steering wheel and the seat and so do other people riding with.
Old Jan 8, 2004 | 05:18 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Check your alignment maybe.
Old Jan 8, 2004 | 05:26 PM
It fell like it is comming from the rear also
Old Jan 8, 2004 | 05:38 PM
1987RX7guy's Avatar
Like I said check your U-joints. My drive shaft would vibrate at different speeds MPH not RPM. Get down there and inspect the joints.
DigitalSynthesis's Avatar
Always something...
Check your diff mounts, your tire balance (often overlooked but a major cause of this is a weight falling off a tire - usually you can get them rebalanced wherever you bought them from for free), and your tires for any uneven wear. If those check OK then you may have a strut going bad, in addition to the things other people have posted here.
Old Jan 8, 2004 | 05:39 PM
How do i inspect the u joints??
Old Jan 8, 2004 | 05:42 PM
Always something...
FSM baby... http://www.fc3s.org should hook you right up. Look under How-Tos -> Manual.
Old Jan 8, 2004 | 05:43 PM
thanks
DaleJK
Aug 31, 2015 10:19 AM
MasteRX
11
Dec 3, 2001 01:43 AM
