Another one of the 'will these wheels fit' threads
Old Jan 8, 2004 | 01:16 PM
amused's Avatar
Can someone explain offset and size to me? I've never been 100% positive.
Just picked up Vosko's MS01s. I can get spacers if i need em but I was curious if these would fit.
17x 8 1/2 with +40 offset
17x 9 1/2 with +38 offset
I wont have em on the car for a while so I was just curious... thanks!
Old Jan 8, 2004 | 01:17 PM
Rxmfn7's Avatar
Do a barrel roll!
No, youll need Spacers. Probably about 25mm should be good.
Old Jan 8, 2004 | 01:20 PM
amused's Avatar
Oks, now can ya explain why? is the offset how deep the wheel is from where it attaches to the hub?
Old Jan 8, 2004 | 01:26 PM
Rxmfn7's Avatar
Do a barrel roll!
Well, the rear ones *might* fit. But they will be sunken in Id think. Stock offset is 40mm for a FC, and thats with a 6-7" wheel. With the 9.5" wheel and only 2 more mm of clearance, Id think you will have seom rubbing issues. Same with up front, where you have less room to work with. Maybe 25mm might be too much though...so better wait until someone else chimes in. Im far from a wheel expert...
Old Jan 8, 2004 | 04:00 PM
$150FC's Avatar
Currently Winning
you bastard, those wheels are great
Old Jan 8, 2004 | 04:03 PM
enrique's Avatar
someone should make a list of what width wheels need to be a certain offset inorder to fit without spacer/adapter.
Old Jan 8, 2004 | 04:08 PM
DigitalSynthesis's Avatar
Always something...
Check the suspension forum. We've got a thread going there just for that purpose. Nobody seems to remember to look there though.
boosted1205's Avatar
If you used the search, it's been talked about for at least couple years.
Old Jan 8, 2004 | 05:35 PM
sicc83's Avatar
You will need spacers in the front, unless you stretch some skinny *** tires on those rims. I'm sure you don't plan on doing that.
The rears might be okay, but it will be tight. You will be very close to suspension/subframe crap. Tire size also comes into play on the back.
I'm running 17x8 +38 w/235/45's in the front, and the tire is just about rubbing the spring perch. I'd like to throw some spacers on there, but I'm waiting to fit my Corksport fenders and lower the car before I do that.
In the rear I'm running 17x9 +35 w/255/40's. They are just about flush with the fenders and fairly close on the inside. I have a little more room to play with in the rear, which makes me think your rears might fit without spacers.
BTW, those rims are sick and I can't wait to see them on your car!
Old Jan 8, 2004 | 06:03 PM
RETed's Avatar
Those wheels are set up for FD3S.
-Ted
Old Jan 8, 2004 | 10:13 PM
amused's Avatar
i know it's for an FD, but why wouldnt it work for an FC ted?
Old Jan 9, 2004 | 04:59 AM
RETed's Avatar
Stock FC wheels are 16" x 7" +40.
Stock FD wheels are 16" x 8" +50.
The tires are almost the same, 205/55/16 for FC and 225/50/16 for FD.
Just by the wheels, the FD rims sit almost 1" deeper.
This is significant.
-Ted
fidelity101
13
Aug 31, 2015 07:47 PM
