Can I add trans fluid through shifter??
Old Jan 8, 2004 | 01:04 PM
JonEQuest's Avatar
Yes, that is my car
I just swapped in a new 5 speed and already have the shifter out can I add trans gear oil through the shifter?
Old Jan 8, 2004 | 01:06 PM
2ndGen.rocket's Avatar
Ho's and Cadillac Doors
no. you can make sure the shift assembly has fluid in it though.
Old Jan 8, 2004 | 02:17 PM
SureShot's Avatar
Seduced by the DARK SIDE
What's inside:
Old Jan 8, 2004 | 02:21 PM
Nice illustration SureShot.
There should be a small amount of fluid inside the shifter assembly so that the shifter functions smoothly. You can't fill the entire tranny through the shifter though, you have to add it from underneath the car. If you're replacing tranny fluid you should probably change out diff. fluid as well.
Old Jan 8, 2004 | 03:15 PM
Aaron Cake's Avatar
Engine, Not Motor
Check out http://www.aaroncake.net/rx-7/transfluid.htm
Old Jan 8, 2004 | 06:02 PM
JonEQuest's Avatar
Yes, that is my car
As usual, your the man, this idea looks perfect.
Thanks,
John
Old Jan 8, 2004 | 06:35 PM
Digi7ech's Avatar
I break Diff mounts
Yeah I used a modified version of your pump with a Arizona IceTea Gallon jug and it worked great.
Old Jan 8, 2004 | 06:59 PM
Sir Rupert Hobo's Avatar
seven-less
another question about filling the tranny fluid.
let's say i took the bad tranny out and put another tranny in. could i fill the new one BEFORE i put it in? i know it would leak on the side where the driveline goes, maybe i could plug that side up?... but what about the front? i don't think any fluid runs through there, cuz the clutch is RIGHT THERE.
sorry to ask, but i threw my old tranny away and i'm waiting for my new one. so i have nothing to look at.
thanks
Old Jan 8, 2004 | 10:20 PM
NZConvertible's Avatar
I'm a boost creep...
Aaron, you've missed the main drain plug off your picture of the Turbo's gearbox. There are two, and you're only arrowed the little one.
Damn good idea though.
Old Jan 8, 2004 | 10:30 PM
amused's Avatar
instead of doing what aaron did, i just threaded a long hose down from the engine bay into the tranny worked fine, no spills
takes 2 to do tho
Old Jan 8, 2004 | 11:08 PM
rx78788's Avatar
this is what i found out about putting the fluid it before you put the tranny in. There is a speedomiter cable( that is atached to the car) that when you detach it, it will drain all the fluid out. so not really, the only way would be is to disconnect the speedo cable from the car. But just put the tranny in that then fill it full. it's really not that hard at all man.
Old Jan 8, 2004 | 11:20 PM
seven-less
got it, thanks..
Old Jan 9, 2004 | 09:37 AM
ultradef's Avatar
Ready to Rock
I just used a cheap hand pump from autozone or whatever and it actually worked really well. And I didn't have to sit there for 20 minutes pumping the handle either. Its not exactly the most comfortable thing sitting under the car and using the hand pump, but it worked well.
Old Jan 9, 2004 | 10:20 AM
Aaron Cake's Avatar
Engine, Not Motor
Oops...I'l correct that when I update the site.
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
Frisky Arab
Sep 4, 2015 06:17 PM
