Replacing heater hose near firewall...
Old Jan 7, 2004 | 10:57 PM
adrock3215's Avatar
Hey,
Had a problem a while ago and the heater hose that runs underneath the oil filter to the firewall cracked.
I just got a replacement hose from Mazda and am wondering if I need to take anything apart to change this hose out. Or is it a fairly straightforward task?
I planned to drain the radiator first and then go at it, but I can't seem to see where the hose goes behind the engine. Please let me know. Thanks!
- Eliot
Old Jan 7, 2004 | 11:06 PM
George84's Avatar
I am back
Its a stright forward task, I am replacing all 3 of my heater hoses tomorrow. You should be able to see both ends of the hoses, just follow the hose to both ends. If u drain the radiator first it should be a simple task. Good luck
Old Jan 7, 2004 | 11:10 PM
86GXL's Avatar
Rotary ≥* Soul
I replaced mine recently. Make sure you check for oil leak problems from around the filter so that it oil wont get on the hose and make it soft and explode. (thats what mine did). Happend to me when i was 300 miles away from home.
Old Jan 8, 2004 | 12:08 AM
silverrotor's Avatar
It's far easier to replace It If you remove your Oil Filter. The rest Is straightforward...as 86GXL mentioned check for oil leaks at the Pedestal. 2 10mm nuts and you are In. Replace the 2 o-rings now. Sooner or later you'll have to anyway.
Old Jan 8, 2004 | 12:28 AM
86GXL's Avatar
Rotary ≥* Soul
Yeah just make sure the Orings stay in the right place cuz one of mine slipped out of place and oil went EVERYWHERE!!!!... lost 4.5 quarts and had to guy buy more.
Old Jan 8, 2004 | 12:57 AM
Not to mention the mess...
Thats why Hylamer Is your friend. Buy It and use It and pass on the Info to the guy beside you. It'll keep things from moving around on you.
whinin
Mar 30, 2019 07:53 PM
LMBTG
Aug 15, 2015 01:43 PM
