a/c rad for oil cooler?
Old Oct 14, 2001 | 10:07 PM
ponykiller's Avatar
I have a 88 TII that I am working on. It had a/c when I bought it and I recently removed it, because I want to get hp from this car. Can I use this air conditioning radiator as a large oil cooler radiator, or even as a second radiator for antifreeze? I want to know if they are the same on the inside-can the a/c hold oil, can it flow oil well enough or can it flow antifreeze?
Any knowledge is appreciated.
thanks
-Kris-
Old Oct 16, 2001 | 09:32 AM
The A/C condensor is certainly able to withstand the pressures of a coolant system or oil system, but the flow rates are another story. Freon is a thin liquid, so there may be a problem with the resistance to flow in the condensor. You would certainly have to come up with a cold oil bypass system, like the stock cooler has.
I dunno. Try it. you may be onto something.
Old Feb 13, 2003 | 08:51 AM
drippa's Avatar
i didn't do it
i believer the holes (piping) for the A/C are way too small and the flow would be way off. Im not sure but this is what i think.
-seth
Old Feb 13, 2003 | 09:11 AM
'Vert in Vegas's Avatar
You will not get any benefits from the flow rate available from the A/C condenser.
For the cost of a oil cooler (less than $100) do it right.
Old Feb 13, 2003 | 09:40 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
on the same subject.. sortof, i know some people have overheating problems during the summer, would putting a small cooling fan on the oil cooler help keep temp's down?
Old Feb 13, 2003 | 09:41 AM
fastrotaries's Avatar
W. TX chirpin Monkey
NO and the stock oil cooler is good for crazy HP.
Old Feb 13, 2003 | 10:21 AM
This is true.
If you have cooling problems, look elsewhere.
