Take a look at my plugs
Old Jan 7, 2004 | 01:50 AM
RotaryForce13B's Avatar
Question Take a look at my plugs
I just changed my plugs tonight and noticed that the rear rotor looks to be running rich and the front rotor is running a little lean. Do you guys think it could be an injector making the front to run lean?
List of mods on my 90 GXL
RB header
RB presilencer
RB mufflers
HKS intake
Removed air pump
Removed ACV
Removed 5th & 6th port sleeves & actuators
E-fan
Old Jan 7, 2004 | 02:29 AM
RETed's Avatar
They look normal to me.
The trailings will always look "richer" due to the fact that some fuel gets shot into the hole first as the rotor sweeps around and the smaller hole through which it fires through.
-Ted
Old Jan 7, 2004 | 02:33 AM
J-Rat's Avatar
Alcohol Fueled!
Reted,
This is a double post...See below..
Rat
Old Jan 7, 2004 | 02:55 AM
RETed's Avatar
Yeah, too late.
Merge threads?
-Ted
Old Jan 7, 2004 | 02:56 AM
J-Rat's Avatar
Alcohol Fueled!
Maybe Icemark will catch it...I cant merge squat...
Old Jan 7, 2004 | 03:02 AM
My88Se's Avatar
to be honest i think the front is running well, the rear looks like its running rich.
Old Jan 7, 2004 | 08:17 AM
wozzoom's Avatar
The front plugs look good for an NA. The rear plugs look pretty gummed up. Couple of thoughts:
1) Bad plug or bad plug wire? Loose boot connection?
2) It's not the coil since the leading plugs use the same coil.
3) More than likely, it's an injector problem. Bad spray pattern or leaking.
wretchedegg
Nov 19, 2025 03:07 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
betes
Sep 27, 2015 08:25 AM
ZacMan
Sep 19, 2015 09:20 PM
Enzo1944
Sep 6, 2015 08:57 AM
