your times with emissions and all
Old Jan 5, 2004 | 03:43 PM
1SxyRXy's Avatar
my fc broke
im just wondering what times any of you are running with AC,PS, emssions and all that junk but upgraded anyway you want, because i belive you dont have to stirp all that off to have atleast a 13second FC
Old Jan 5, 2004 | 04:47 PM
Scott 89t2's Avatar
SOLD THE RX-7!
removing PS, AC, and emmissions makes you no faster. 13 secs with all that is easy.
Old Jan 5, 2004 | 04:54 PM
Sideways7's Avatar
Removing PS and AC is going to save you weight, but not much time othwise. They only slow you down when they are being used, which puts a strain on the engine. Removing emmisions will get you a little extra speed, but I dont really know how much. Im sure theres threads about the advatages of removing emmisions. You should still be able to at least a 13 second car with all that stuff, though.
Old Jan 5, 2004 | 07:15 PM
1SxyRXy's Avatar
my fc broke
i know removing all that stuff gives you a lot of space to work with
Old Jan 5, 2004 | 08:29 PM
ponykiller's Avatar
Removing catalytic converters are a great way to get more power from a rotary engine (especially the turbocharged variant), and usually the first thing done when looking to increase hp.
It would be cheaper/easier to get into the 13s if you got rid of emissions, but if you really want to spend the extra money to keep emissions, then it is possible.
Old Jan 5, 2004 | 08:33 PM
1SxyRXy's Avatar
my fc broke
well i just ment like things on the engine not like stock dp and cat.
Old Jan 5, 2004 | 08:46 PM
NZConvertible's Avatar
I'm a boost creep...
The only emissions-related part that affects performance is the cat. If you have an aftermarket hi-flow cat even that won't make much difference.
Old Jan 5, 2004 | 10:02 PM
ponykiller's Avatar
So what are you wanting to keep? If you get rid of your cats, then there is no reason to still have an air pump. What other emissions devices would you want to keep, because they will have close to no effect without cats.
streetlegal?
Mar 17, 2022 02:46 PM
incubuseva
14
Sep 3, 2015 12:37 PM
