Finishing my t78 install
Old Jan 5, 2004 | 03:36 AM
RiON's Avatar
To who purchased the t78 kit there are 2 extra steel braided lines i did the feed and return what are the extra ones for?
Old Jan 5, 2004 | 08:00 PM
R-magic's Avatar
I believe those lines are for the wastegate.....
Old Jan 6, 2004 | 03:25 AM
RiON's Avatar
wastegate?
Old Jan 6, 2004 | 06:45 AM
allrotor93's Avatar
yeah the lines to the wastegate are wrapped in stainless so they look like drain lines.
Old Jan 13, 2004 | 07:45 PM
RiON's Avatar
what u mean?
Old Jan 13, 2004 | 08:12 PM
UltraJuaN's Avatar
There are two fittings that screw into the type-r wastegate. The two stainless steel lines screw into those fittings. The other side of the stainless steel lines have vacuum fitting adaptors that screw in. one side is threaded and the other allows you to put a hose on it. I'll post a picture for you.
Old Jan 13, 2004 | 08:25 PM
UltraJuaN's Avatar
They are actually vacuum lines to the wastegate. They use stainless steel reinforced line to protect them from the heat coming off the manifold and downpipe.
Old Jan 13, 2004 | 08:28 PM
bcty's Avatar
Boost This!
RiON do u know what a wastegate is?
Old Jan 13, 2004 | 09:39 PM
RiON's Avatar
yes i do and htanks for the pics!
Old Jan 13, 2004 | 09:43 PM
RiON's Avatar
I was also having problems mounting the stock raidator i knwo it came with adapters but need more info or pics thanks!
Old Jan 13, 2004 | 10:14 PM
bcty's Avatar
Boost This!
should look into something better them the stock rad with a T78 too.. whats your parts list so far? what fuel mods u running?
Old Jan 13, 2004 | 10:15 PM
RiON's Avatar
Greddy T78 turbo kit
Greddy FMIC type 32 core
Cosmo Fuel pump
1200cc Injectors
Apex ecu with the commander
midpipe/ apex gt spec exhaust / dp
Old Jan 13, 2004 | 10:16 PM
RiON's Avatar
i was just gonna use the stock rad for temp too till i get fundings
Old Jan 14, 2004 | 01:22 AM
bcty's Avatar
Boost This!
sounds good
Old Jan 14, 2004 | 02:19 AM
RiON's Avatar
think if properly tuned what are the chances of it blowing up?
Old Jan 14, 2004 | 09:51 AM
RacerXtreme7's Avatar
NASA geek
You need a better fuel pump if your gonna run boost anywere close to that turbos efficieny range. hmmm injectors are a bit small also. Don't run too much boost till you get those and a radiator.
Old Jan 14, 2004 | 06:25 PM
UltraJuaN's Avatar
Sorry haven't mounted the radiator yet, we have the fluidyne stock replacement. Still waiting for greddy to send the instructions and downpipe for the kit. But I've been taking a lot of picture incase I decide to do a write up, since noone has really came forward to help on the question I had about the power steering cooler. I think we're going to bypass teh power steering system and remove the pump and ac compressor.
I'll try to keep you up with pics. Should be mostly done this weekend.
Old Jan 14, 2004 | 10:12 PM
RiON's Avatar
Yeah the pics would help alot thanks im also a little confused the the power steering line? all in japanese
whinin
Mar 30, 2019 07:53 PM
apooch
Sep 4, 2015 10:27 AM
tiger18
Sep 3, 2015 08:27 PM
