another newbie
Old Jan 2, 2004 | 03:45 PM
Newbie
Red face another newbie
I've been lurking about on this and other forums, and I would like a little more info on 1st brake upgrades. So far I've seen the $2k kit and heard about GSL-SE suspension swaps. I also read an article about a swap from an FC. My car is an '83 and Iwould like to know if there is any particular trim level that I should use as a donor car to keep cost and fabrication to a minimum. Five lugs would be nice, but four is not a deal breaker.
Old Jan 2, 2004 | 03:59 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
to keep it simple just do a GSL-SE swap. they will give you the 4x114 bolt pattern so you can use basicly any rim in 4 lug you want.
there is no fab req. direct swap.
Old Jan 2, 2004 | 07:56 PM
Newbie
how far do I go with that swap? just hubs, brakes and spindles? or is there more that i should take?
Old Jan 2, 2004 | 07:59 PM
wwilliam54's Avatar
it WILL run
the whole rear end
and then the whole front strut assemblies
Old Jan 2, 2004 | 08:03 PM
mazdaverx713b's Avatar
Have RX-7, will restore
that is essentially the whole swap. in addition the spindles (whole front strut assemblies as quoted above i think) would be to your likeing. better and biger brakes. welcome to the club!
Microtech
30
Apr 23, 2016 06:37 PM
Moppet52
Feb 4, 2002 02:14 PM
Daw Tse
Nov 16, 2001 10:59 AM
