Will a Nikki feed a 13B
Old Jan 2, 2004 | 08:15 AM
inittab's Avatar
I read your email
I was wondering if a Nikki from a 12a would feed a atockport or streetport 13B? What would need to be modified on the Nikki to make it flow enough?
Old Jan 2, 2004 | 09:04 AM
Jeff20B's Avatar
Lapping = Fapping
I nabbed a Nikki that was on a 13B. The engine was waterlogged, so I never saw or heard it run. One thing about the Nikki manifold is that it has channels that connect the primaries to the secondaires. M Nikki happened to be sitting on a fully seperate runner Hitachi style 13B manifold. The top of the manifold was redrilled to the Nikki bolt pattern. I took all that 12A stuff off and put an Hitachi on it, and it worked fine (I had to move the studs back to their original holes).
I guess the Nikki flows better when it has channels under it, according to peejay. Personally, I don't really know.
I'm glad the PO didn't hack up this 13B manifold. It's going on my freshly rebuilt R5 13B. Oh, and the Nikki pattern is going to come in handy when I try an Edelbrock experiment.
Old Jan 2, 2004 | 10:37 AM
Rx7carl's Avatar
Airflow is my life
It will run, but getting it to flow enough would be tough. RB sizes a Holley 600 for a 13B if that tells you anything. My work has yielded a 470CFM Nikki, and I'm lookin for more. But gettin 600 outta it is a tall order.
Old Jan 2, 2004 | 10:54 AM
nlc1179's Avatar
coldy13 has the nikki on his 12a and that thing is putting out at least 300hp at the flywheel. the car that was using it before him was putting out around 500hp. you just have to know how to mod it.
Old Jan 2, 2004 | 11:33 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Gee whiz, Carl.
Looks like we have more to learn than we thought.
Old Jan 2, 2004 | 12:26 PM
Metallic_rock's Avatar
Ride 'n Style
well, I have a Nikki from a 12a on my 13b 4 port, but I also have a Sterling Carb on order if that tells ya anything. I just doesn't seem to have nearly the power I should. Even though I do have mech secondaries already.
BTW- Sterling, I can't freakin wait to install that carb!!
Old Jan 2, 2004 | 01:05 PM
Sterling's Avatar
Huh?
...What carb?
Old Jan 2, 2004 | 09:48 PM
Rx7carl's Avatar
Airflow is my life
Originally posted by Sterling
Gee whiz, Carl.
Old Jan 2, 2004 | 10:06 PM
REVHED's Avatar
Hunting Skylines
Does the word boost mean anything to you?
Lou Byer
20
Oct 12, 2020 08:03 PM
Joe's_7
Sep 8, 2015 04:44 PM
