Non-Seq./single Turboed-Emissions passing?
Old Oct 13, 2001 | 08:20 PM
Immanuelrx's Avatar
Going Non-Seq. on my stock turbos. I bought a block-off plate kit and wanted to know what stuff should I not block-off(like EGR valve, etc. ) to pass emissions. I am planning to keep air-pump if I have too. Or can i delete everything a have the PFC running lean at low boost when the test comes around? Basically I just want to know what it takes to pass emmissions!!
Old Oct 13, 2001 | 10:32 PM
vosko's Avatar
Just Call Me Terminator!
the only single turbo kits that might pass emissions are the HKS kits. pretty sure
Old Oct 14, 2001 | 01:00 PM
Immanuelrx's Avatar
Thanks, But I am going non-seq. soon and wanted to know will I have problems with emissions??
Old Oct 14, 2001 | 03:03 PM
vosko's Avatar
non sequential will produce the same emissions as sequential. it shouldn't make a difference
Old Oct 14, 2001 | 05:36 PM
Immanuelrx's Avatar
Thanks for replying,
Even if i have the block-off plate kit and I block-off all solinolds not needed???? Like the EGR Vavle and rid of the air pump and so on?????
Old Oct 14, 2001 | 07:07 PM
Nameless's Avatar
I could be wrong with your state's smog law...but over here, no air pump is an automatic fail. If you do it maybe u can find someone who could just help you out for a couple extra $$.
Old Oct 14, 2001 | 07:17 PM
Immanuelrx's Avatar
Ok air pump stays!!!
Can I rid the EGR Vavle??
Old Oct 14, 2001 | 08:33 PM
Nameless's Avatar
The EGR is an emmisions control device...so I would think you should keep it on to pass. The EGR recirculates the a little exhaust gas to decrease the NO2 levels right? Depending on how strict Philly is you might want to keep it on.
Old Oct 14, 2001 | 10:40 PM
vosko's Avatar
when the time comes around i'm just gonna $$$ an inspection sticker. my car passed when i got on the first try but i will not be that lucky again.
JP's 93 fd
Sep 16, 2015 01:12 PM
