Best Turbo For stock to street ports for 12A
Old Dec 31, 2003 | 12:41 AM
jorx81@aol.com's Avatar
Still Dreams of 3rd Gen
Which turbo would be best for stock to large street port?
draw through and blowthrough, most likely a blow through holly.
Thanks
Joe
Old Dec 31, 2003 | 12:46 AM
coldy13's Avatar
Yeah, shutup kid.
For stock port running up to 16psi the stock turbo from a TII is a good size. I don't know much else though, since that's the only setup I've tried.
Don't even think about doing draw through, blow through is much better in every way.
Old Dec 31, 2003 | 01:30 AM
What a/r's, would that work on a big streetport well too.
excuse my ignorance of turbo's
Old Dec 31, 2003 | 02:02 AM
81Rex6port13b's Avatar
I Push My Car Real Fast!
t3/t4 turbo will do great.
Old Dec 31, 2003 | 02:06 AM
Gregs's Avatar
i plan on turboing my engine with a s5 turbo and im going blowthrough ala rotary shack
-greg
Old Dec 31, 2003 | 10:22 AM
hiboost7's Avatar
for a stock port 12a use a s5 TII turbo.
for a street ported motor dont think of using anything with a t3. go with a TO4 series turbo like an E,R,B. also you may want to run a big a\r for less heat, but with a ptrim for quicker spool.
Old Dec 31, 2003 | 10:54 AM
Stoops417's Avatar
Straigt T04? that's a big turbo! Can the 12A sp really push that big of a turbine and still be drivable? I was thinking of going with a 14b off of a DSM... not very big but should be good for around 250 HP and spool up quickly. But i'm very new to Rotarys... so maybe i'm about to learn something
Old Dec 31, 2003 | 07:05 PM
REVHED's Avatar
Hunting Skylines
A 12A is 2.4l in piston engine terms so any stock turbo you might find on a four banger will usually be too small. Plus the strong rotary exhaust pulses are just made for spooling big turbos.
Old Dec 31, 2003 | 08:34 PM
Stoops417's Avatar
great, i learned something! I've had a RX-7 for two days and i'm already Loving it AND this forum.
Old Dec 31, 2003 | 08:52 PM
Stoops417's Avatar
I wonder what size a TII turbo is??? I see that the Greddy upgrade for them is the 20-G, would the stock size be comparable to an 18-G then?
Old Jan 1, 2004 | 05:29 AM
180sx-x's Avatar
Zoom-ing Goon.
for greddy size talk, a TD05-16G is a good size turbo, an HKS GT3032 (although a 3238 or 40 is probably better) or T04S, an IHI VF3140(IIRC) is good, a Garret GT30R or t4/T4s(yes, T4/T4s), an APEX'i Isamu RX-6 turbo is good, although may be a bit too big...an i can't think any off my head...so, ect...
Old Jan 1, 2004 | 11:05 AM
Stoops417's Avatar
well, i'm going to be looking to the small end of the spectrum. Not too small, but still something that will spool up quickly, as the car will be used a lot for auto-x. I also will be looking for some junkyard turbos or something used, just for the sake(wth? sp?) of cost
Old Jan 1, 2004 | 12:13 PM
Stoops417's Avatar
Just to make sure we are speaking the same language...
the one on the right is a 14b off of a stock DSM, the one in the middle is the good ole' T3/T4 hybrid and the monster on the left is a TO4E...
Old Jan 1, 2004 | 03:41 PM
hiboost7's Avatar
if your worried about spool go with a s5 turbo, and take it to get modified to your specs. for street daily use. the porblem with the s5 ( almost like a t3) is that they are too small and cause heat issues. TO4's are great turbo's. and if your thinking of using a stock dsm turbo, those are even smaller than s5 turbos. turbos are good investments, but make sure your making the right investment, do it right the first time....go TO4
Old Jan 1, 2004 | 05:07 PM
REVHED's Avatar
Hunting Skylines
I agree. S5 turbo is definately the way to go if you don't want to spend much.
hiboost7, what heat issues are you talking about with the S5 turbo?
Old Jan 1, 2004 | 05:44 PM
setzep's Avatar
I'd go 60-1, .6 comp housing, p-trim turbine, .84 housing.
Old Jan 1, 2004 | 06:07 PM
hiboost7's Avatar
ive heard that using a stock turbo II turbo restricts alot on a street ported motor.
Old Jan 9, 2004 | 11:18 AM
brianmcd's Avatar
I was thinking of doing an s5 tII setup. Engine will be streetported, though, so TO4S is the way to go? Will there be much lag? How much psi can you boost on one?
~brian
Old Jan 9, 2004 | 12:05 PM
Rotofire's Avatar
Yea, I'm working on it...
i want a good cheap turbo for a stock 12a. where would i fiind one? i found a TII driveline on ebay for like a 100 bucks, maybe more now cuz that auction just started. i am a virgin when it comes to turbos so i wanna try one, lol. i still don't know where to start looking, how much am i looking to spend and on what to get my car on the street with a nasty howl in its engine bay? any help would be very much appreciated...just doing a bit of research.....oh yea lamens terms please like i said i don't know much about them yet.
Old Jan 9, 2004 | 12:26 PM
rotofire, you need to buy my weber.
Old Jan 9, 2004 | 12:27 PM
Rotofire's Avatar
say whaaaaat?
Old Jan 9, 2004 | 12:36 PM
pm'ed you.
Drive down here and I'll put it on for you.
Joe
Old Jan 9, 2004 | 12:50 PM
Rotofire's Avatar
i was told it came with the manifold....and it needs smaller jets
edit: sorry about the thread jacking, we'll continure through pm
Old Jan 9, 2004 | 04:35 PM
Don't apologize dude, it's my thread.
I though it needed smaller vents, because you can't stomp it below 3500, but from what
I hear that's normal for a weber.
It probably does need smaller idle jets, (1100 idle).
Other than that the carb screams it's damn close as brand new as you get, I also I have a spare set of gaskets you can have with it.
sherff
Feb 24, 2019 12:09 PM
