Arcing Wires/Coils revisited
Old Dec 30, 2003 | 06:18 PM
rcksuprstrMX6's Avatar
Ive asked the question before, I replaced my wires cap and rotor along with a coil and I still have problems with a bad miss and arcing coils/wires. Could this be an issue with a bad ignitor or maybe just cheap wires? Any help would be great.
Old Dec 31, 2003 | 01:59 AM
rhinor61's Avatar
Cheap wires. Ignitor has nothing to do with high voltage arc, except for the fact it is triggering the coil to fire the 60,000 volts thru the coil wire, to the distributor cap. Thru the rotor to the spark plug.
Must be pretty on dark winter night to pop the hood while the engine is running.
Buy some decent plug/coil wires.
John
Old Dec 31, 2003 | 03:04 PM
slashdawg00110's Avatar
RTFFAQ
clean the coil towers and the cap towers, too. Then use dieletric grease in the wire boots.
Old Jan 1, 2004 | 10:02 AM
Ive cleaned it up
Still arcing, Im taking the cheap *** wires I was talked into buying back and getting the Bosch set, any better than the Autozone cheapies?
Old Jan 1, 2004 | 02:07 PM
faye x7's Avatar
brilliantly stupid
NGK Plugs and NGK Wires is what I say!
Old Jan 9, 2004 | 12:16 PM
Put on a brand new set of Accel 8mm's
STILL doing it, this is bullshit any help?
Old Jan 9, 2004 | 12:33 PM
Rotofire's Avatar
Yea, I'm working on it...
could somthing be grounding itself out?
Old Jan 10, 2004 | 02:22 AM
rhinor61's Avatar
Where do you see it arcing at?
Cap, coils?
BTW what year cars is this?
J-
Old Jan 10, 2004 | 06:31 PM
85 12a
Ive replaced one coil, the cap, rotor, wires, and plugs. Any help?
Old Jan 10, 2004 | 08:53 PM
Steve Shulz's Avatar
Where is it arcing at exactly? Electricity will take the easiest path to ground it can find so if its accesible it will.
Old Jan 10, 2004 | 08:55 PM
wwilliam54's Avatar
it WILL run
get new wires
napa has good wires for a good price in my experience
Old Jan 10, 2004 | 08:59 PM
I think he has other issues than plug wires, he's on his second set. Need to know where its arcing at..
Old Jan 14, 2004 | 05:44 PM
UPDATE
I got two new coils today and am going to swap tonite
96fd3s
38
Apr 19, 2021 06:50 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
