Tilton Multiplate clutch for FD?
Old Dec 30, 2003 | 12:01 PM
rx7tt95's Avatar
Photo Diety
Anyone know of a shop that's familiar with using a Tilton in an FD with the stock transmission? Interested in a dual plate carbon/carbon (yes, I'm aware of the cost!) and purchasing one from someone who's already done the conversion once before. Thanks for any head's up info!
Old Dec 30, 2003 | 04:25 PM
IronMdnX's Avatar
Glutton for Punishment
I have a twin Ceramic Tilton. rated for 700 foot lbs. I did it through unorthodox. They make a lightweight flywheel and use tilton disks, pressure plate, clutch slave cylinder T/O bearing combo. The setup is overkill for a 13b, but I'm using it on a 20b. You can slip the clutch and isn't too bad for drivability. I didn't take any pics of the clutch before install unfortunatly.
Old Dec 30, 2003 | 05:48 PM
93 R1's Avatar
What kind of modifications are necessary?
Old Dec 30, 2003 | 06:31 PM
IronMdnX's Avatar
No modifications really, replace the clutch slave , arm , T/O Bearing with Tiltons Hydrolic T/O Bearing. You just need to fab 2 lines ( from Clutch hose to new t/o assembly and a bleed line).
Here is a couple pics i found for a supra. Basicly the same thing.
Old Dec 31, 2003 | 10:43 AM
93 R1's Avatar
So it does away with the slave and engages/disengages with hydraulics?
The1Sun
Sep 15, 2015 04:45 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
risingsunroof82
Sep 9, 2015 08:06 PM
