Go Back   RX7Club.com > Tech and Performance > Rotary Car Performance > Other Engine Conversions
Old 12-28-03, 09:21 PM   #1
bandit86
New Member
LS1 v8 vs 13bt weight
I was on a camaro board where someone seemed to think he knew a lot about rx7s.... He said the LS1 v8 engine swap in a complete car weighed as much as a stock rx7. I thought wankel motors were super lightweight. Would all the turbo plumbing make it comparable to a v8 weight?
bandit86 is offline   Reply With Quote
Old 12-28-03, 09:55 PM   #2
Nowhere
Send a message via AIM to Nowhere Send a message via Yahoo to Nowhere
HA, wholy snit! A blown lt1/350 weighs like 500 lbs with tranny!
I thought the rotaries only weighed about 300 ish with tranny.
Suzuki samurai, soon to be rotary powered!
Originally posted by Center of The Universe
Comparing Rally to Nascar is like comparing chocolate to shit.
Nowhere is offline   Reply With Quote
Old 12-28-03, 09:58 PM   #3
bandit86
New Member
LS! have "plastic" intkaes, and aluminum heads. Very light, not much more than 450 pounds, plus tranny. I thought the rotaries to be at 250pounds plus trannies, but I dont know what the turbo and all the plumbing weigh.
Old 12-28-03, 09:59 PM   #4
Sideways7
No Sleep, No Food
Sideways7's Avatar
Send a message via AIM to Sideways7
I dont have any concrete answers at the moment, but I see no way a chevy 350 and a 13BT weigh the same. Not to mention the fact that installing one in a rx-7 will mess up the handeling and weight dist.
1987 RX-7 - s4 J-spec turbo swap
RB 2.5" DP/presilncer to Apex N1; Hawk HPS pads; KYB AGX shocks with Ground Control coil-overs; Ground Control caster/camber plates; ACT Prolite Cro-moly Flywheel, Haltech E6X
Coming soon - BNR Stage 3 hybrid turbo!
Sideways7 is offline   Reply With Quote
Old 12-28-03, 10:04 PM   #5
1Revvin7
The answer is simple
1Revvin7's Avatar
Trader Score: (10)
Send a message via AIM to 1Revvin7
I thought an all aluminum ls1 weighs very close to a stock 13bt (325#s)
1Revvin7 is offline   Reply With Quote
Old 12-28-03, 10:25 PM   #6
Sideways7
No Sleep, No Food
Sideways7's Avatar
Good point revvin, I forgot about them being all aluminum. Theres a company that offers instructions and some equipment for v-8 converions on rx-7's using early 70's vette engines. Those are cast-iron, which is what I was thinking about.
Old 12-28-03, 10:43 PM   #7
Josepi
Despise Enmity
Josepi's Avatar
Swap website: www.grannysspeedshop.com or www.grannyspeedshop.com
in either way, I'd take the LS1 with a proper tuned EMS. Yes, I'm throwing myself into the flames of purist, but shit you sons of bitches, I appreciate the chassis and engine. To worship the engine alone would be ass-in-nine.
My sig hosting crapped out...
91 TII - MicroTech LT-8, A'pexi Dual N1 CB, Thunderfab 3" DP, TurboXS DSBC, TurboXS BOV...
83 GSL
Josepi is offline   Reply With Quote
Old 12-28-03, 10:53 PM   #8
Sam
big boost baby
Sam's Avatar
Send a message via AIM to Sam
I remember a Ebay auction that had a 87 SE with a V8 swapped. The seller said it was about 300 pounds heavier with the V8 instead of the 13B
Sam is offline   Reply With Quote
Old 12-28-03, 11:47 PM   #9
digitalsolo
RX-347
digitalsolo's Avatar
Send a message via AIM to digitalsolo
The LS1/T56 is about the same weight as a 13BT/tranny, and LIGHTER then a 20B/tranny....
The cast iron/AL head engines are around 150 lbs heaver (with a T56) and around 225-250 lbs heavier with an auto (though the rotary is heavier with an auto too, obviously).
This will be in V8 conversions soon... non negative mentions of pistons don't last long on the 2nd Gen board.
Your wheels don't fit and your headlights are broken.
digitalsolo is offline   Reply With Quote
Old 12-28-03, 11:49 PM   #10
MtnRacer
infini guru
MtnRacer's Avatar
Send a message via AIM to MtnRacer
Re: LS1 v8 vs 13bt weight
What they don't tell you is that they've removed power steering, ABS, A/C and/or a number of other items, and often, the motor chosen uses a automatic transmission, and so on and so forth.
Steve
MtnRacer is offline   Reply With Quote
Old 12-29-03, 10:41 PM   #11
cdk 4219
The LS1 T56 88 TII that I have registers 2785# on the Longacre scales. The engines are heavier than a 13b (LS1 T56 completely dressed and with driveshaft is approx 535#) but the supporting hardware of the rotary makes up the difference. And yes my car has power steering, but it doesnt have AC which is usually dead weight on most FCs because it doesnt work anymore. All in all it made the car do everything much better than the rotary engine.
cdk 4219 is offline   Reply With Quote
Old 12-30-03, 06:28 AM   #12
Sponge Bob Square Pants
Sponge Bob Square Pants's Avatar
Just like MtnRacer said 2 posts above this,
It's not just engine-to-engine weight comparisson. Different accessories are replaced, altered, even stuff you wouldn't think of like a new exhaust system, air ducting, new brake rotors, crap like that change the weight.
If you want to know which engine is heavier, then it's obviously the LS1 package, period.
Which car would be heavier betwen the LS1 RX-7 and a stock RX-7 Turbo, well that can vary from one project to the next, so you can't really say.
Sponge Bob Square Pants is offline   Reply With Quote
Old 12-30-03, 10:45 AM   #13
onikageka
I swear, if I see one more V8 RX7 weight bashing thread I'm going to lose my damned mind!
onikageka is offline   Reply With Quote
Old 12-30-03, 11:17 AM   #14
digitalsolo
RX-347
...this thread has been quite civilized... no real bashing, just good, somewhat informative discussion really. I'm quite happy to see it handled maturely...
P.S. rotaries suck! (I AM OF COURSE JUST KIDDING!!!)
Old 01-05-04, 09:56 AM   #15
1point3liter
93 R1 - Turbo LS1
1point3liter's Avatar
mine weighs 2700lbs and has perfect 50/50 weight distrobution. *shrug*
1point3liter is offline   Reply With Quote
Old 01-26-04, 09:06 PM   #16
blackkiller7
blackkiller7's Avatar
this is nothing but BS , their is only like a thirty pound difference
blackkiller7 is offline   Reply With Quote
Old 01-26-04, 10:43 PM   #17
MosesX605
I have webbed buttocks
MosesX605's Avatar
Send a message via MSN to MosesX605
What people seem to forget is that no matter how light a 13B is, turbos and their associated manifolds tend to be REALLY heavy. I have no trouble believing that an all-aluminum V8 is similar in weight to a 13BT.
RX no more...
MosesX605 is offline   Reply With Quote
Old 01-27-04, 02:06 PM   #18
gnx7
Here is a thread from another board on the weight of a Buick GN Turbo V6:
I weighed my motor complete minus the tranny, converter and starter. It weighed 420-lbs with everything just (including wiring harness and ECM)as you would sit it in a Regal. I weighed the 200-4R seperately w/ a 10-in non-L/U converter. It weighed in at 162-lbs. Add those two together and you have a grand total of 580-lbs for the T/R drivetrain.
Here is the same thread about the LS1:
Got the LS-1 motor weighed today with all the accesories attached (A/C, P/S, Alt, wiring harness, ECM; etc. Believe it or not it weighed in at 481-LBS !!! That is only 61-LBS more than the TB. Keep in mind that the Buick was weighed with all accessories inluding the turbo, intercooler, ECM, wiring harness, headers and DP.
I believe a T56 (6 speed) weighs around 140lbs. The 4L60E automatic version is about the same as a TH200-4R at 140-145lbs.
The fact that 1.3Litres LS1/FD weighs 2700lbs and has basically perfect 50/50 weight distribution should open some eyes. His car hauls butt as well.
Here is Hinson's LS1 powered FD:
TEA ported Heads, 231/237 Cam , ASP pulley
Ported TB, CNC Ported Exhaust manifolds, Cold Air Intake - Not installed during those runs
With 100hp NOS shot the car has gone 10.1@137mph with a T56 6speed nonetheless! I imagine with some road race oriented suspension and big wheel/tire combo this car could tear it up on a road race track.
-GNX7
'87 RX-7/Buick GN power 11.62@114mph: stk GN turbo R.I.P.
'93 FD/LS1/T56: GABs,TriPoint bar,delrin bshgs,439rwhp/385rwtq thru cats n/a on 91
11.42@127.4mph SOLD
new project: FD/LS7/T56: Penskes, CCW's, RB BBK, 550rwhp: mid 10's@140mph n/a
gnx7 is offline   Reply With Quote
Old 02-11-04, 06:16 PM   #19
tbielobockie
Send a message via AIM to tbielobockie Send a message via Yahoo to tbielobockie
Re: Re: LS1 v8 vs 13bt weight
Wow.... you guys are like the flat earth people...
Despite huge amounts of proof to the contrary you still believe the Earth is flat.
Lets set the record straight: The LS1 conversion, with power steering and A/C weighs 2700lbs and still has 50/50 weight distro.
And contrary to the rotary purists hopes and dreams.. the v-8 RX-7 handles better. Here is why:
* flat torque curve. means you have power everywhere with no turbos to spool or lumps in the powerband to throw you sideways
* instant power at all revs meaning you can adjust the amount of power you want at the exact instant you want it
Steve
tbielobockie is offline   Reply With Quote
Old 02-12-04, 02:17 PM   #20
383Mazda
Rotorite
Send a message via AIM to 383Mazda
This is a good point! Torque on demand is a HUGE plus no matter what type of racing you're into...
Here's something else to think of...
lets be VERY generous and say you have a 2,600lb rx7 making 250hp from the 13b motor... that's 10.4 lbs/hp. Now for the anti V8'ists, lets be bogus and ad 600lbs to your rx7 and say your V8 only makes 300hp... so you now have a "ruined" rx7 that weighs 3,200lbs and makes 300hp.. that's still 10.6lbs/hp
(Now imagine that you're in the real world, lets play it safe and say your cars weighs 3000 lbs and makes 450hp from the V8... I won't make you think, that's 6.6lbs/hp!!!!)
In the V8 swap, if car will gains weight it won't be because it's gotten fatter, it'll be because it's gained a lot more MUSCLE!!!!
Brandon
'86 Turbo Regal: 7.82 @ 84mph in the 1/8th mile
'86 Rx7 GXL - 12.93 @ 106.5 4500ft elevation
383Mazda is offline   Reply With Quote
Old 02-14-04, 02:46 AM   #21
Dyre
Your Opinion is Wrong
While im in no way a rotary purist (inital stages of my LS1/FC are underway) there are some key differences in the weight distro of a LS1 FC/FD. While the balence is close to stock, the LS1 DOES sit further forward and higher in the engine bay. The weight is now dirrectly over the front steering and past it. Technically the car is no longer 'Front/Mid engine' with the LS1 like it is with the triangle motor. While it won't make a difference in most cars is DOES change some key factors of handling.
All things being equal (they arent- but just for comparisons sake) the weight placement with the rotary is far better for polar-moment of inertia and other such characteristics.
Fact is, though, the added low end grunt and power of the LS1 will make it faster around a road course/autox/drag strip than the rotary car despite the less than perfect drivetrain placement.
Really, both car setups have thier merits.
'88 TurboII
YOUR ALTEZZAS ARE GHEY!
Dyre is offline   Reply With Quote
Old 02-16-04, 07:44 AM   #22
tbielobockie
That is nothing but pure marketing bullshit from Mazda. And you swallowed every last little bit of it.
If Mazda gave two shits about any of that stuff they wouldn't have stuck the battery as far forward and as high as possible.
Old 02-16-04, 08:20 AM   #23
projekt
projekt's Avatar
where would you put it mr. accomplished engineer?
projekt is offline   Reply With Quote
Old 02-16-04, 10:40 PM   #24
thant
Well since they took all of that time and effort to put an insulated cover on it as well as making it an integral part of the hokey pokey intercooler and battery ducting, you would think that they could take some extra time and put it in the huge "package" compartment. Seems like it might be the right thing to do, evenif it has to be vented. That excerpt was taken directly from my Mr engineering book.
thant is offline   Reply With Quote
Old 02-17-04, 02:29 PM   #25
Dyre
It has nothing to do with marketing- Its called physics. You might try to read up on it. Polar Moment of Inertia is a key factory to how a car feels and reacts when racing.
How many people here consider leaving the battery in the stock location for a race car (road or drag)??? Anyone?? Anyone?? Didn't think so. We all know moving the battery improves the weight placement and feel of the car... It should be easy for you to under stand then how having the same ammount of weight 7 inchs futher back makes a difference when we are talking about an item like an engine.
Hell, the most popular MUSTANG k-members move the motor down and back as far as possiable for the same reason the rotary sits completely behind the front steering. It improves handling and feel.
Its not marking BS, its fucking fact. Unless you are going to cut out the firewall and move the LS1 back 8 inches it is always going to be a less desirable engine position than a 13b/12a. Can you compensate for it? Yes. Can you probably still be faster due to the extra hp? Yes. Is the LS1 just as good for overall chassis setup and drivetrain location? No.
Like I said, I like both options. Both setups have thier place.
13b, 13bt, 5050, distribution, engine, fd, gm, keeping, ls1, ls1t56, rotary, rx7, t56, v8, weight, wieght
Top
