what suspensions u r using??
Old Dec 26, 2003 | 12:09 PM
MRV3's Avatar
im looking at getting aftermarket suspensions for my 7 as i found the front left one is a bit soft already.
just wondering what brand of suspensions u guys are using??
and rating??
Old Dec 26, 2003 | 01:14 PM
AntiVenom7's Avatar
Wouldn't Go If U Paid Me
use the freakin search
I am running stock suspension with Koni Yellows. I havent needed anything more than what the stock suspension gives......so far. course I've only had it for about a month. I've been too busy making it faster in a straight line.
Old Dec 26, 2003 | 01:29 PM
XSTransAm's Avatar
Ee / Cpe
im told hks hypermax damper 2's are one of the best for our cars.
Old Dec 26, 2003 | 02:07 PM
rynberg's Avatar
I don't know about that -- they don't offer seperate ride height/spring pre-load adjustments and they also run the same spring rate front/rear, which would normally cause some pretty narly oversteer.
Unless you are an experienced track guy, pick up some springs (H&R for example) and some adjustable shocks like Konis and try that out for a while.
Old Dec 26, 2003 | 02:11 PM
the_glass_man's Avatar
Will u do me a kindness?
TEIN HA's with pillowmounts, M2 toelink and trailing arms with JimL bushings.
Old Dec 26, 2003 | 02:42 PM
MRV3's Avatar
i m not an experienced track guy, probably will go on track one or 2 times a year, mainly for Sunday cruise on mountain roads, so i'll be looking at getting something not too hard, but not too soft neither.
anyone here tried apexi? or jic?
Old Dec 26, 2003 | 02:50 PM
David Beale's Avatar
I put in the H&R sport springs. They are firmer than the RB ones that were in there before, but they are not harsh. Still using the stock shocks. The springs solved a problem I was having with the tire touching the inner fender liner (front) under hard cornering on the highway.
Old Dec 26, 2003 | 04:24 PM
alberto_mg's Avatar
Koni adjustable shocks should do you just fine. They are even height adjustable so you really don't need to do springs if you don't want to. When you replace them, do the upper strut/shock mounts and spring pads. That will make the suspension quieter and the rubbers are probably all shot anyway.
All coil overs will be stiff. Most use spring rates up over 400lbs/in usually in the 500lbs/in range.
Old Dec 26, 2003 | 05:36 PM
Mahjik's Avatar
Mr. Links
If you want something not too hard but not too soft, think about some Tokico 5-way Struts with some progressive springs (Eibach or something else).
The progressive spring rate will feel nice on the street but give you a little more aggressive handling when you need it.
Old Dec 26, 2003 | 10:10 PM
jspecracer7's Avatar
1JZ powered
HKS Hiper-D Drag. But the car's primarily a drag car.
Old Dec 26, 2003 | 10:23 PM
racer1's Avatar
flying apex seal
I am using HKS hyper damper's and they are great. Fully adjastable and excellent handling and feeling.
Old Dec 27, 2003 | 02:55 AM
180sx-x's Avatar
Zoom-ing Goon.
well, if you want stock goodness, than 93 R1 springs and struts are a good thing. I can tell you, since i own an R1, they are pretty stiff, but provide stock goodness. Now i have Tokico Ilumina 5way struts and Racing beat springs, and they are perfect for me. But for all out, i'd go with JIC FLT-A2...or not.
Old Dec 27, 2003 | 03:20 AM
spoolin93r1's Avatar
anyone experience the tein flex? i'm in need of coilovers too and they're just barely within my budget
Old Dec 27, 2003 | 03:53 AM
Roar 629's Avatar
i use tein flex almost 2 yrs.. and it's great for daily and city driving..
Old Dec 27, 2003 | 06:10 AM
that's what i wanted to hear. any problems whatsoever? i'm mainly needing the different settings for street/auto-x/drag. i like to do everything and don't want to compromise anything, so i want full adjustability to do so. i really like the idea of having the pillow mounts to so i can adjust camber. did they come with one for the rear or just the front?
Old Dec 27, 2003 | 07:01 AM
Re: what suspensions u r using??
and rating??
Since you are in Australia I would check out the (DMS) Drummond Motor Sport coilovers. They make a very nice heavy duty setup, and they are based in Australia.
Old Dec 27, 2003 | 01:07 PM
POM HB's Avatar
Lookie Only
I love my old Mazdaspeed coilover. People complain they are soft...but, I like it a lot because it's 'soft' for street comfort. I don't drive mad quick or drift or drag anyway.
POM HB
Old Dec 27, 2003 | 01:38 PM
Jesuscookies's Avatar
I can haz rotary?
I have the JIC FLT A2's. I think they are a fair compromise for the car. Much nicer than the Tokico illuminas I had. You can also get custom spec ones, and bring the spring rate down if the 9/12's are too much for you.
Old Dec 27, 2003 | 01:40 PM
Little 7's Avatar
H&R coilover, Blistein makes its shock . Its cheaper than Hipermax.
Old Dec 27, 2003 | 03:15 PM
GsrSol's Avatar
Z06 powered FD
WS6 shocks and springs and modified swaybars.
Old Dec 27, 2003 | 07:35 PM
ws6, as in the trans-am?
Old Dec 27, 2003 | 10:05 PM
fd3s_rx7's Avatar
that'll be ur stock.
They are good at not too soft and not too hard.
Old Dec 27, 2003 | 11:32 PM
user 9348703's Avatar
I have APEXi, I want BUDDYCLUB..
Old Dec 28, 2003 | 12:40 AM
I'm going with JIC FLT-A2.
Old Dec 28, 2003 | 08:21 AM
cournal's Avatar
JIC FLT-A2.
i love them, don,t waste your money on springs and struts. go coil overs
