new torque brace....
Old Dec 25, 2003 | 04:03 PM
BoostCrzy's Avatar
Doritos on a toothpick
here is the new torque brace i recently built....let me know what u guys think....
Old Dec 25, 2003 | 04:09 PM
widebody2's Avatar
addicted to lounge
Looks real good for one you built yourself. How is the difference when driving. Is the car louder overall. Vibrations? Any gains?
Old Dec 25, 2003 | 04:16 PM
BoostCrzy's Avatar
very solid shifting under load.....vibrations are better than a solid brace.....my previous brace was solid tube...this time i decided to incorporate the shock....fully adjustable(shock dampner and rod length)...softens the vibrations considerably while retaining the rigidity needed to restrain motor movement....
Old Dec 25, 2003 | 09:20 PM
911GT2's Avatar
The Power of 1.3
What are these lines here? I don't remember those being there.
Old Dec 25, 2003 | 09:29 PM
Mean Machine's Avatar
brake lines to/from ABS i believe not sure though...
looks like a nice set up though are you going to be selling them?
Old Dec 25, 2003 | 09:53 PM
rx7raca's Avatar
wHiTe kNiGhT
hey your paint in your engine bay looks so amazing new. even your engine looks really new. how many miles are on the car? everything looks like its brand spanken new!!
clayne's Avatar
PV = nRT
911GT2,
Those are on every car. He just mounted his lower than normal so they pass under the lines (probably bent them upwards) rather than above.
Make sure that spring is very stiff. If you have any significant displacement under load then there is no point in having the brace.
Old Dec 25, 2003 | 10:00 PM
911GT2's Avatar
The Power of 1.3
Originally posted by clayne
911GT2,
Oh wow, I didn't realize those were the same lines. I just looked at a few pics of my brace install and saw them. My brace looks like it clears those by a good 2 inches, there must have been some serious bending going on there.
Old Dec 25, 2003 | 10:06 PM
93rotorhead's Avatar
Looks great Im in the market for one, let us know a price if your going to sell them?
Old Dec 25, 2003 | 10:22 PM
RonKMiller's Avatar
Blow up or win
Looks good. I built one similar a while back with a gas spring - it really worked well.
The only problem was that it was masking the real problem: a broken OEM driver's side mount and a worn passenger side mount.
What cracks me up is that an entire cottage industry has been born because of poorly designed mounts - that have been dramatically improved by Mazda - and are readily available for $370.00 shipped from Malloy.
I gotta say it sure is alot easier slapping on a "torque brace" - whatever - than installing new motor mounts, which IS a monster job.
I think you'll find if you take the effort to install some new, updated OEM motor mounts you'll find that crisp shifting return, and you won't have to worry about transient vibration stressing other components and your upper intake manifold engine hanger bracket - which was designed for vertical - not horizontal - loading.
If you're running high HP you need urethane mounts.
Old Dec 25, 2003 | 10:24 PM
911GT2's Avatar
The Power of 1.3
Woah, did RonKMiller just suggest the pre-fabbed, readilty available fix over the ghetto, cheap, do it yourself fix?
Who the hell are you and what have you done with Ron!
Old Dec 25, 2003 | 10:27 PM
RonKMiller's Avatar
Blow up or win
I'm his evil twin.
Old Dec 26, 2003 | 07:55 AM
rxrotary2_7's Avatar
911GT2,
or he has a 95... where they are different location...
Old Dec 26, 2003 | 03:05 PM
BoostCrzy's Avatar
its a 93...and yes i did have to "slightly" bend the lines up...lol.....but its not bad....and the spring and shock are very tight....i am not currently planning on producing them yet...but if need be...i am prepared..lol..... the shock is out of an aircraft seat so getting them is kind of an issue....but i can buy them new....
Old Dec 31, 2003 | 08:16 AM
BoostCrzy's Avatar
car has 49k mi. BTW....motor has bout 3k.....just broken in .....
Old Dec 31, 2003 | 08:54 AM
moehler's Avatar
my lines bend up like that too... it's nice to finaly see it on another car. I always thought that someone messed with mine at some point .
RedBaronII
Sep 20, 2015 11:29 AM
