b & M shifters
Old Dec 23, 2003 | 07:57 PM
YeL_Rx7's Avatar
b & M shifters
Its really hard for me to go from 1st to second and also 3rd to 2nd. You have 2 full slam it, it makes it hard for daily driving, does anybody have the same problem???thanx
Old Dec 23, 2003 | 09:04 PM
RedX7's Avatar
I swear my car hates me!
Two things will help you greatly:
1. An engine torque brace (Think what you want, know it helped my shifting)
2. New motor mounts. Obviously, this one is quite a bit more expensive and time consuming, but if you have the engine pulled for any reason-do this mod!
I hope that this helps a little.
Old Dec 23, 2003 | 09:23 PM
WaLieN's Avatar
Call me gramps!
Re: b & M shifters
I don' t think the problem is within your shifter, rather, it might be the transmission itself. As mentioned before, it could also be the motor mounts. With any short shifter, it requires even MORE effort for it to get into gear.
Old Dec 23, 2003 | 11:02 PM
there was a thread already about this not too long ago. And it seems that most people had a problem with getting it from 1st to 2nd with B&M ss. I have the same problem, but only when the car is cold. It doesn't bother me though.
Old Dec 23, 2003 | 11:19 PM
wiblergt's Avatar
same problem here. i never realized it would be HARDER to shift with this thing.
Is the engine torque brace the thing that mounts under the hood on the passenger side?
Old Dec 24, 2003 | 12:14 AM
spoolin93r1's Avatar
i have one and it's never given me a problem. 100x better than the stocker
Old Dec 24, 2003 | 12:15 AM
Sprockett's Avatar
Former Rotorhead
Just give it a chance to break in a little bit - after a few weeks, you won't even notice it.
Old Dec 24, 2003 | 01:16 AM
theorie's Avatar
AponOUT!?
yah a new short throw wont help too much if you are already having problems.
i have this nice B&M and i love the throws, and i also have a FEED engine torque brace, but i had my syncros replaced just a few months ago. maybe if i had the stuff sooner it might have helped save my syncros, but whatever..... i love the throws now atleast!
Old Dec 24, 2003 | 04:47 AM
sevenin7's Avatar
Mazdaspeed shifter is the best !
Old Dec 24, 2003 | 08:48 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
What's the difference?
Oh, and I have had no problems with my B&M. Took some getting used to, but no problems.
Old Dec 24, 2003 | 09:10 AM
Conv.WS6's Avatar
you could try making sure the stops are set correctly. The B&M in my C5 had to be adjusted a bit.
I can't remember if the spring tension can be adjusted on them for the side to side movement.
I was actually thinking about making my own shifter to lock out 1 and 5 unless you have a handle pulled. That way you can't miss third even if you want to.
that's my only complaint about the stock shifter.
Old Dec 24, 2003 | 09:15 AM
Mahjik's Avatar
Mr. Links
The Mazdaspeed (and it's replicas) are about a 50-66% reduction (depending on the site selling it as what they list as the reduction) where as the B&M is 33%.
Old Dec 24, 2003 | 09:18 AM
clayne's Avatar
PV = nRT
I could never imagine going back to stock shifter or steering ever again.
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
