greddy smic with single?
Old Dec 22, 2003 | 08:43 PM
mr g lord focker's Avatar
Have no idea...can the GReddy SMIC work with a single or only the twins? Looks liek my BNR turbos are **** so I am thinking about single but I already have the GReddy SMIC. Push comes to **** I am sure I will have a bunch of you who would be interested in a GReddy SMIC! =) Lemme know
Old Dec 23, 2003 | 04:04 AM
anyone know?
Old Dec 23, 2003 | 05:33 AM
inis's Avatar
personally, im pretty sure i WILL NOT work. you could always make your own piping, but keep in mind, if you buy a single kit, you will probably want a FMIC.
Old Dec 23, 2003 | 06:46 AM
Mahjik's Avatar
Mr. Links
It will work (provided you have the piping). How well it will work will most likely depend on the turbo you use. I've seen people stick single turbos on the stock IC, not that it's a good thing.
You'll just need to check your intake temps (which you should be able to do with your PFC).
Old Dec 23, 2003 | 02:07 PM
thanks guys...if my bnr's are truly shot I will be most likely running the single on this Greddy SMIC. IT is a bit bigger than stock and was told it will hold around 20 psi on the twins. So I am thinking running 17 or so PSI on the single should work w/o too much trouble...
Old Dec 23, 2003 | 02:14 PM
books's Avatar
Zooq...was selling a single setup that had intake piping to a Greddy SMIC...so it appears it has been accomplished
msilvia
15
Sep 11, 2015 12:13 PM
