Garfinkle's Engine Pics (56K NO)
Old Dec 22, 2003 | 06:49 PM
djmtsu's Avatar
DGRRX
I had to have a freind scan these for me but they still look great. David wanted me to post these here. So for all those who have or have not seen his car/engine, enjoy!!!!!
Sorry for the HUGE PICS.
Old Dec 22, 2003 | 06:51 PM
djmtsu's Avatar
DGRRX
Heres more
Old Dec 22, 2003 | 06:52 PM
expl0d's Avatar
He make that cold air box? looks really good.
Old Dec 22, 2003 | 06:59 PM
C-westin'FD's Avatar
Nice and clean!!!
Old Dec 22, 2003 | 07:03 PM
93BlackFD's Avatar
built my own engine
constant torque worm gears? why didn't he go with t-clamps
and what's up with the non polished alternator?
Old Dec 22, 2003 | 07:24 PM
djmtsu's Avatar
DGRRX
Alternator coming soon I think. And I'm not sure why he didn't use T-clamps. To each his own.
Old Dec 22, 2003 | 07:28 PM
sub-zero's Avatar
Chrome the alternator, while it is being rebuilt, much easier. I like the constant torque clamps also.
Looks good David.
Old Dec 22, 2003 | 07:48 PM
duboisr's Avatar
the alternator is going to be replaced with a polished one that puts out 160 amps at low rpm and 260 at high rpm . If the price and supply is good they will be for sale from an alternator builder that builds them for sound comp cars .
Old Dec 22, 2003 | 08:27 PM
AgentSpeed's Avatar
BNR built motor and twins
Very nice and shiney!
Old Dec 22, 2003 | 08:36 PM
jeff48's Avatar
Rotorally Challenged
That is really coming together. Great, can't wait to get there and see it for real. The custom wiring harness keeps everything neat and clean.
Old Dec 22, 2003 | 08:37 PM
rotorbrain's Avatar
fart on a friends head!!!
you guys cant even know the greatness of this vehicle till you see it in person. its absolutely awe-inspiring!!!! my kudos to david garfinkle for building the BEST all-around FD i have ever known to exist.
paul
Old Dec 22, 2003 | 10:52 PM
911GT2's Avatar
The Power of 1.3
Wow, thats awesome. I'm very impressed.
How about some exterior shots? Mods list for the stuff we can't see? (Fuel, engine management, exhaust, etc.)
Old Dec 22, 2003 | 10:57 PM
SNracing's Avatar
aka KingDrunk
bling bling! like the chrome
Old Dec 22, 2003 | 11:12 PM
HEns's Avatar
nice and clean, unlike mine
Old Dec 22, 2003 | 11:33 PM
0110-M-P's Avatar
Too Many Projects
Wow that looks really good (the alternator throws it off a little, but not too bad)
Old Dec 22, 2003 | 11:40 PM
pomanferrari's Avatar
The way the turbo outlet to the IC is the way it should be done. However, it ain't that easy to do to an M2 IC pipe that has compound bends to allow for the use of the airpumps.
Why does Garfinckle use another blowoff valve in the Greddy elbow?
For 20K miles, I was boosting at 13-14psi with the stock blow off valve.
After I pulled the turbo which had 100K miles of use with 20K on 13-14 psi, I didn't see any cause for concern with compressor surge damaging the turbo shafts. What was more of a concern was the exhaust eating away at the turbo manifold.
Old Dec 23, 2003 | 12:02 AM
duboisr's Avatar
He has 3 blow off valves, so the turbos do not slow down between shifts .The two stock ones have had the springs changed so they are closed at idle .They open at 18-19 inches. so no lost air during idle and low revs .
Old Dec 23, 2003 | 12:32 AM
1st to 3rd's Avatar
All that and $9 Dayco belts from Autozone.
All I can say I Niiiice!
Old Dec 23, 2003 | 12:47 AM
fd3s93's Avatar
i likes! and glad to see there isnt any colorfull hoses.
Old Dec 23, 2003 | 01:48 AM
duboisr's Avatar
That is a $ 10 belt and with homemade pullies you try cheap ones untill you find the correct size with out ordering several costly ones . When the high output alt is put in and the pully size is chosen then the better belts will be found . We went out to eat in the car tonight and the smooth power is a rush . As written above ,, glad to see there isnt any colorfull hoses .Do you see any rubber vacuum hoses at all beside the brake booster hoses .
Old Dec 23, 2003 | 03:00 AM
jimlab's Avatar
Super Snuggles
Probably because they work just fine and that's what came with the ASP Racing medium IC he has...
Old Dec 23, 2003 | 03:09 AM
jimlab's Avatar
Super Snuggles
Pardon my doubting, but the stock CRV and BOV are not "serviceable", in that they're plastic, fused together. Are you insinuating that he opened them up, tested springs until he found ones that wouldn't open until 18-19 inches of vacuum, and then closed them back up again? If so, does his engine pull 18-19 inches of vacuum? I know mine sure as hell didn't and I've never seen another rotary engine that did. Of course that doesn't mean one doesn't exist, but you'll forgive me for assuming that this sounds a little, shall we say... embellished?
Old Dec 23, 2003 | 01:06 PM
duboisr's Avatar
Jim lab you of all people know that anything is serviceable . The crv and bov valve can be taken apart. He took them apart and then Rotorbrain gave him another black valve to respring so he would have two matching in color . The spring he found to work came from a small bore Yamaha motor cycle clutch . If you doubt then you will be incorrect .There are others that have some skill but none that come close to you . Garfinkle can do wonders if he had the time and money .Money is his bottleneck .
Old Dec 23, 2003 | 01:12 PM
ptrhahn's Avatar
Whats in the custom-fitted tank in between the IC duct and intake? Overflow tank? Sprayer/WI injection source? OMP dedicated supply? James Bond oil slick?
Old Dec 23, 2003 | 02:46 PM
rotorbrain's Avatar
omp dedicated source holding amsoil synthetic 2 cycle oil.
paul
