radio buzzing
radio buzzing
in my 80 ls when i turn the radio on i can hear the song but there is this awful constant buzzing. even when i turn the volume all the way down the buzzing remains the same. it is a stock factory radio. what could be the problem? i suspect a faulty ground. where should i begin to look? it has the original plugs and wires(only 57K on the car, it is pretty much mint i have heard cases in which this caused radio interference, but they are the correct p/w). thank you, dave
well, i will give that a try. i didn't want to replace many of the original parts, as about 95% of the car is factory original. i suppose it can't hurt. the car runs perfect. you could balance a glass of water on the air cleaner and it wouldn't even think of jarring off. i'll order a new set and keep the old ones as spares. my garage is littered with boxes and bins of spare parts. i am an rx-7 parts pack rat.
Does the buzzing noise change at all if u rev your car up or get on it. If it does, check your fuel pump ground, thats happened on a few other cars of mine. The pump grounds through the stereo and u get to hear everything it does.
Trending Topics
Originally posted by mazdaverx713b
i am not sure what you are talking about inittab.??? what is it's function?
EDIT- Victoria British sells 'em.
well, is it only for 79-80 models? i will check on it when i get home on monday.
well, i looked and could not find it. do you have a pic? i saw something mounted to the left side in the engine bay, almost up to the firewall. it was almost bell shaped and had a connector that trailed down into another connector. i thought that may be it but remembered you had said it was on the block.
Dave, I remember that condensor. It was that piece that we were wondering about on that locked up motor that we ATF'd. I think we left it on the motor, so we can try swapping it tomorrow when you get back.
yeah i figured it out in 04, i guess i just forgot to post. a buddy of mine reminded me of this thread and suggested that i update it..so i did. i guess a channel in the amplifier is bad causing the buzzing.
RyanFox
Sep 18, 2015 09:09 PM
