Exhaust overheating light came on since pulling rad and putting in electric fan....
Old Dec 20, 2003 | 09:12 PM
rotary_neubie's Avatar
Like the topic says..... Pulled the rad yesterday, installed the taurus fan, replaced rad, drove home. Let car idle for 20 minutes next day, to burn off all the extra anti-freeze that is in the engine bay, and check for leaks. Take it for a quick rip after warming up, and the warning light for the exhaust temp came on. 1st time in 2 months of owning car, and driving hard regularly. The coolant level sensor is just grounding out right now on the negative terminal of the batt, cause that broke yesterday. Not havin much luck here.... Anyone know what could suddenly cause the overheating of the exhaust system light to come on? could it be cause of the coolant sensor? Or maybe an air pocket in the anti-freeze somewhere? Does the stock fan move air over the exhaust to keep it a little cooler?
Old Dec 20, 2003 | 09:29 PM
85rotarypower's Avatar
love the braaaap
The breeze from the fan wouldn't even touch the exhaust where the sensor is. Its under the passenger seat. The only thing I can think of since the two systems are in no way related in wiring, is that a cat got clogged for some reason. Either that or the exhaust just got really hot from idling for 20min standing still with no air flow around it.
Old Dec 21, 2003 | 05:18 PM
Its weird.... it won't come on all the time.... just once and awhile. I parked at Mc'd's, the light was off, went in ate, came out, started it up. the light was then on...drove for 5 minutes... pretty hard, and it went off?????????????????!!!!?????!!?!?!?!!
Old Dec 21, 2003 | 06:22 PM
Rx7carl's Avatar
Airflow is my life
Sounds like coincidence to me. Your cat may be clogged, causing the overheat, or maybe the sensor/wire went bad. Look under the car next time to see if your cat is glowing red hot.
Old Dec 21, 2003 | 10:30 PM
Ok thanks Carl.... Where would I be without your help....
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
torky007
Aug 17, 2015 05:14 PM
