Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
What signal causes an injector pulse?
Old Dec 20, 2003 | 02:52 PM
chris_stampe's Avatar
Question What signal causes an injector pulse?
I cant believe that this hasnt been posted, and it probably has, but I cannot find it anywhere. My question is simple, what signal causes an injector pulse? The reason I need to know is because my AIC is being tempramental and not working sometimes. It seemed like a bad ground, but Ive regrounded a million times. I get 12v at both prongs on the injector connector. I figured that one of those 12v must become a ground in order for the injector to open, but I just need to know for sure so I can continue testing the aic and trying to find the problem.
Thanks,
Chris
Old Dec 20, 2003 | 04:40 PM
Project84's Avatar
Open up! Search Warrant!
From looking at the FSM, pins 3F, 3C, 3H, and 3E on the stock ECU are the signals to the 4 injectors. (page 50-22 in the FSM). I don't have a diagram to show what pins those are. Are you trying to piggy back the signal to the AIC off of the stock wire harness?
Hey, where did you get your TO4b? Pm me.
Old Dec 21, 2003 | 08:49 PM
RETed's Avatar
Typically +12VDC is constant on. The actually fuel injector signal is a ground square wave. It's a "pull down" or "pull to ground" signal.
-Ted
Old Dec 22, 2003 | 02:45 PM
so let me get this straight for sure. the 12v is constant, but there is a 12v to ground wave and the different frequency is what allows the injector to control the pulswidth time....right? So I should test both leads coming out of the aic and see that one of them has a pulsing ground? Thanks
Old Dec 22, 2003 | 06:46 PM
RETed's Avatar
Yep, you got the theory right.
I doubt your DMM would "see" the pulse. An analog meter might be able to show it, but most "cheapie" DMM's will not show the pulses accurately. You really need an o-scope to show those pulses - got one handy?
-Ted
Old Dec 23, 2003 | 05:18 PM
Sean McElderry's Avatar
Or a test light in case you don't have a scope lying around
Old Jan 11, 2004 | 11:30 PM
J.S.J's Avatar
the engine computer is the end all decision maker on the ground side but remember there is a power side and subsystems which tell the computer there is an engine running/rpm/ ignition system signal as well.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
connerfd3s
Sep 19, 2015 05:58 PM
