High end power fade
Old Dec 17, 2003 | 05:25 PM
Matty's first 1st Gen's Avatar
Boosted 7
High end power fade
My 83 GS, is acting funny, at high Rpm, rather 3500-4000, during Wide Open throtle the car loses power, and feels like its really leaning out badly. It doesn't happen during half throttle at high rpm, only full throttle. Also its not really noticable in 1st or 2nd just mainly 3rd and up. I was thinking either the secondaries, or fuel pump issue. i used to have mech secondaries, but they were removed for winter about 3 weeks ago, the problem arose a few days ago. Thanks in advance. ~Matt
Old Dec 17, 2003 | 05:40 PM
Rx7carl's Avatar
Airflow is my life
Fuel delivery problem. Possibilities. Pump not adequate, regulator restricting flow, filter clogged or partially clogged, return line restrictor not in place, carb last chance filter screens clogged (theres 4 total, 2 brass screens at the banjo's, and 2 plastic cone screens under each needle seat). Tank screen clogged, or ice in the bottom of the tank.
Old Dec 17, 2003 | 06:27 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
I would start with replacing the fuel filter. It's high in the probable cause list and low on cost, then fuel pump and then the rest of the well enumerated items Carl gave. But yes, definitely fuel delivery problem. Had the same symptoms in mine a few weeks ago - fuel filter handled it.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
