Warm up time
Old Dec 16, 2003 | 11:54 PM
heb09's Avatar
Warm up time
Ok guys, I'm a n00b with rotories so here are some n00b questions:
Whats a reasonable idle warm up time when shes cold?
When driving on a cold motor, whats the maximum revs to take her out to? for me its 3000rpm
And how critical is it that the motor is FULLY warmed up before stopping her again?
Old Dec 17, 2003 | 09:30 AM
oni-dori's Avatar
Back from the dead
i usually warm up my car about 5 mins when its less than 50deg. and i also shift at 3k if it hasnt fully warmed up yet.
as for the shut off, the driver's guide on the on the rx-8 says it should reach halfway of normal operating temp before shutoff. so i just go with that rule.
Old Dec 17, 2003 | 12:01 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
I usually warm up about 2-3 minutes on cold mornings, but this is after bringing the car out of the garage which is probably about 60 when it's 35 outside.
As a rule of thumb, I wait until the temp gauge comes up off of the pin before I drive it, preferably until the needle is on the lower mark on the 'C' side. After that, I don't push it above about 2500 rpm, since the oil isn't up to speed and likely isn't even getting very good pressure to all the components until it reaches standard operating temperature.
After it hits the standard temp, I drive it like normal. Shut down after driving is about 1-2 minutes of idle speed, and then I rev it up to about 2k to get oil pressure up a bit and then turn the key off. This gives a last burst of oil pressure into the rotors which should help to keep it oiled as it's spinning down. As long as the engine is turning, the oil pump is running and pushing oil, but at lower pressure until it's at a dead stop. HTH,
Old Dec 17, 2003 | 12:44 PM
82transam's Avatar
Never Follow
I let it run for a minute or two before moving on a cold morning but tahts it, I take it real easy though until its fully warm and never shut it off unless fully warm
Old Dec 17, 2003 | 01:59 PM
Lisa's Avatar
I let it warm up for the time it takes me to smoke a cig - about 5 minutes. Then again, here in Cali it never really gets that cold.
Old Dec 17, 2003 | 02:29 PM
I hit the key and go no matter what temp.
Old Dec 17, 2003 | 04:33 PM
oni-dori's Avatar
Back from the dead
that's my timer too!
Kyo
Apr 13, 2019 09:24 AM
sherff
Feb 24, 2019 12:09 PM
Jun 26, 2016 10:21 AM
Microtech
30
Apr 23, 2016 06:37 PM
PhillyFC
Aug 21, 2015 06:36 PM
