Have ne idea what this noise was?
Old Dec 16, 2003 | 08:04 PM
sam 13bt ke26 conversion's Avatar
Newbie
well today I went to a friends house to show him my 84 gsl-se and give n' a lil ride. He doens know **** about rotary cars so i told n' tha it was a piece of **** slow like a turtle. Well i made a couple of burn outs and doin a burn out i heard this laud noise tha i thought was a flat tire i got off and all tires were just fine. I got back in the car turned it on and the car had this laud noise comin from the tranmission, first thing i thought " damn I just fuked up my transmission" . Ok after tha I took my friends bak and on my way to my house the laud noise just went away like if never was there.
has this happened to ne of ya'll?
Old Dec 17, 2003 | 06:38 AM
bizarro's Avatar
when was the last time you changed the tranny and diff fluid?
Old Dec 17, 2003 | 10:28 AM
racermike's Avatar
aheadau
Well that's really tuff since you don't describe the noise? Since you were doing burnouts, I would guess either the front u-joint, or the transmission mount. A broken mount would allow the assembly to move around, and the driveshaft may be contacting a heat shield.
Old Dec 17, 2003 | 12:40 PM
Lotus00's Avatar
Yeah, but if you break a mount, you know it. i had one go and the shifter sunk ~2 inches and wobbled around a bunch.
Old Dec 17, 2003 | 01:24 PM
racermike's Avatar
aheadau
Lotus, sounds like the entire rubber part came off in yours. Usually it only tears from one side but stays in place. When that happens the transmision tail can move about under load, but at rest it would be back in the (relatively) normal position.
Old Dec 17, 2003 | 02:43 PM
Lotus00's Avatar
yeah, mine was in pretty bad shape
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
betes
Sep 27, 2015 08:25 AM
Linda_Lovelace
Sep 18, 2015 10:04 PM
zxrazorxz
Sep 14, 2015 07:21 PM
