v8 rx7
Old Dec 13, 2003 | 09:23 PM
yerlee4's Avatar
v8 rx7
why haven't there been much talk about the 5.0 ford motor in the 3rd generation rx7. i know the ls1 is overall better engine than the 5.0 but the prices are way different. 5.0s go for under 1g at the junk yard whlie the lowest price for a ls1 i found was $3500. with intake and heads and other things, the 5.0 can run with the ls1.
Old Dec 13, 2003 | 09:27 PM
diablone's Avatar
Wow you really want to go cheap don't you? 1K on a chassis and another 1K on an engine isn't going to finish it. Try the "Other Engine Conversions" section of this forum.
Old Dec 13, 2003 | 09:33 PM
XSTransAm's Avatar
Ee / Cpe
It wouldent be worth it to convert the 13b to a 5.0, your much better off with the wankel... That being said tho I wouldent convert it to anything, the wankel is what makes this car so unique.
Old Dec 13, 2003 | 09:43 PM
BrianK's Avatar
I believe it has to do with size. The Ford motor is too tall to fit under the FD's hood.
Old Dec 13, 2003 | 11:18 PM
yerlee4's Avatar
okay thats the answer i was looking for.
Old Dec 14, 2003 | 03:05 AM
yerlee4's Avatar
okay, even though you answer my first question i have another. can someone give me a website address were some did do this swap?
Old Dec 15, 2003 | 09:41 PM
turbogarrett's Avatar
0 lbs of boost
check out torquecentral.com in the v8rx7 forums. the 5.0 seems to be a popular swap with the 1st gens. it can be mounted in any gen, but like it was said before it is too tall and would require a hood scoop or you could bust out the sawzall and go with the "trailerpark" air cleaner sticking out of the hood
Old Dec 18, 2003 | 09:24 AM
TOUGHGUY's Avatar
Got some screws loose!
The attractiveness of the 302 and 5.0, other than brand loyalty, is in its thinwall design. Physicaly, a SBF is marginaly narrower and shorter than a SBC. Contrary to popular belief, the overall height of a SBF is about the same as a SBC due to Ford`s general use of lower profile air cleaners and EFI intakes. The SBC is however, about 1.5 inches shorter from the oil pan to valve cover than a SBF. What the thinwall design achieves is the overall weight of the engine assembly is more than a hundred pounds lighter for a Ford than a Chevy without loss of structural integrity. Ford`s placement of the distributor at the front of the engine also makes it attractive for tight fits into smaller cars such as the RX7 where firewall modifications are usualy avoided.
I like Chevys just as much as Fords because they are cheaper and more abundant but the old addage that it takes a 350 to beat a 302 isn`t just an old wives` tale!
Toughguy
Th0m4s
Feb 26, 2019 02:04 AM
