Electrical Problems
Old Oct 9, 2001 | 10:24 PM
Got Rotors?'s Avatar
Electrical Problems
Can anybody tell me how to fix my tail lights/Marker lights? I know that they are on the same circuit. The brake lights work fine but my marker, tail, interior lights dont.
CAN ANY BODY HELP ME FIX THIS???
Old Oct 9, 2001 | 10:59 PM
Icemark's Avatar
Re: Electrical Problems
The brake lights have nothing to do with that circuit.
There is a red/black wire coming down from the light switch. This wire should be hot (have 12volts+) on it when the light switch is on. If it does not then check to see if the White/green wire coming from the switch is hot. The White/green is coming from fuse # 6 in the interior fuse box. You will of course want to check that wire/fuse first.
If they both have power when the light switch is on, either all the bulbs are burnt out (very unlikely unless you have been jusmp started recently) or there are bad grounds to the bulbs (something got disconnected).
If the red/black never gets 12v on it no matter what position the switch is, then the switch is bad and needs to be fixed or replaced.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
