Cone filter
Old Oct 9, 2001 | 10:15 PM
Northern 7's Avatar
Cone filter
Anyone out there using a cone filter on their 1st gen? I'd like to hear more about the setup, ie; what brand, anything need to be fabricated, adaptable to a cold air intake (poor man's), where to buy, and is it much of an upgrade from a reg. KN in the cannister
Old Oct 10, 2001 | 10:27 AM
jimmyv13's Avatar
Round&Round not Up&Down
Why do you want to use a cone filter?
Old Oct 10, 2001 | 06:35 PM
Northern 7's Avatar
I've heard the cone filter is a better set up with a cold air intake -maybe I'm way off base here but I currently have a cold air intake set up to the snorkle and I've heard the cone works better.
Old Oct 15, 2001 | 09:10 AM
jimmyv13's Avatar
The cone on the CAI must be placed out of the engine bay to be effective....where did you plan on installing yours? I don't think the fenders have enough room in them. I am in the middle of making a CAI with the K&N cannister. I have a 3" pipe running down to the pass. side of the radiator and through the sheetmetal. I still have to cut the hole, but I'm getting close. Do a search for Pittdp and look through his posts, I'm doing the same set-up. If I find the link, I'll post it.
Old Oct 15, 2001 | 09:22 AM
jimmyv13's Avatar
Here Pittdp's set-up
Good luck and have fun
Old Oct 15, 2001 | 07:50 PM
Northern 7's Avatar
I have a similar set up to this in place now - only difference is I moved my coolant overflow to the strut tower to make room for a 4" hose ( I used 4" aluminum flex hose) - looks like Pitt left his where it was (Pitt, nice engine bay by the way) - It works well unless its a cool damp day and then I get icing problems
I've heard of a cone filter set up that allows you to fab on a cold air intake and do away with the cannister set up - I've never seen it, only heard people talking about it - maybe's it's a myth.
Thanks for the response
Old Oct 16, 2001 | 01:20 PM
jimmyv13's Avatar
Look at the 2nd gen's and see if you can copy that. I've never seen a gen2 engine bay, so I couldn't tell you.
Prediict
32
Nov 18, 2015 08:41 AM
Devon Murray
Sep 25, 2015 09:41 AM
msilvia
15
Sep 11, 2015 12:13 PM
