Will these fit??
Old Dec 10, 2003 | 07:24 AM
chucksrx7's Avatar
Wink Will these fit??
I want to get some bigger rims for my 1986 rex n/a will these fit... 19X7.5 , 4X100/4X4.5 dual bolt pattern, offset ET42
Old Dec 10, 2003 | 08:21 AM
Godzilla-T78's Avatar
HOLY **** MAN. 19s? You are seriously going to slow your car down ALOT, id go with 17s.. 18s MAX
Old Dec 10, 2003 | 11:13 AM
DCrosby's Avatar
No it's not Turbo'd
Yeah 19's = Okay for Showcar, but your wheel wells are going to hate you for it
Old Dec 12, 2003 | 12:08 PM
how do 18's affect the wheel well and such looking at getting a set of work termist s1-c wheels and they only make 18's or 15's.
Old Dec 12, 2003 | 03:31 PM
hyper7's Avatar
the only way the wheel wells will rub is 1) lowering the vehicle 2) tire size is too wide for application 3) new wheel and tire combo are taller than stock. sometimes these changes wont cause rubbing however if you have done one of the above you are subject to rubbing.
Old Dec 12, 2003 | 03:35 PM
hyper7's Avatar
as far as slowing your car down ALOT, thats not entirely true. if you measure how tall your tires are now and compare them with 19" tires and they are close there wount be a change unless the difference between the two is large.
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
