WIll my tires rub. See pictures.
Old Dec 10, 2003 | 03:36 AM
Spinner-D(eluxe)'s Avatar
I have these new Diamond Racing wheels and am wondering if I wil need to do any fender modifications. THey are 15x7 in the front with 4" backspacing, so they stick out a little (about 1"). I have plenty of clearance in the rear (3.5"), but in the front I only have 1.5" of space between the top of the tire and the fender. I tried jumping on the strut top (I am 160lbs) and in the 5th position (Illuminas stiffest) I could get only .75=1" of travel. Under hard cornering do you think I will get any rubbing? The tires I am using are Kumho Ecsta V700 in 225/45-15.
Old Dec 10, 2003 | 03:39 AM
ioTus's Avatar
'84 5-letter
is there any question? your tires stick out like 2"...
I guess the best way to tell is to drive it. if you hear something that sounds like tires rubbing, then yes, they rub....
Old Dec 10, 2003 | 05:46 AM
Lt. Dan's Avatar
I doubt they'll rub.
Dan
Old Dec 10, 2003 | 06:39 AM
S2-13BT's Avatar
Yes, they'll rub!
I had about a cm of tire sticking out at one point using stiffer than stock suspension and slightly damaged my front gaurd. Don't risk it dude!
Old Dec 10, 2003 | 06:52 AM
nlc1179's Avatar
i think it will be close. they will probably rub at full steering, but for most street driving they should be fine.
Old Dec 10, 2003 | 06:57 AM
Rx7carl's Avatar
Airflow is my life
Well on my racecar, we run a bunch of negative camber (static) on the front and they barely clear. Oh and the fender lips are rolled. I think you will get some rub if the strut compresses enough.
Old Dec 10, 2003 | 07:20 AM
jimmdog's Avatar
Hell Yea there Gona rub Unless You drive like a P (Non gratitious cursing Nice) The First time you go around a corner with a dip in it Its gona Go Runnt I Have done it!
Old Dec 10, 2003 | 08:01 PM
Whats the best way to modify fenders? Rolling them is what I have heard, but how do you do that? DOes it involve making lots of little cuts perpendicular from the edge, and bending the metal inwards and up??? Can this be done and still look ok?
Old Dec 10, 2003 | 08:04 PM
no it's not that much (only 1" at the most), but it doesn't matter, because any distance beyond the fender outer edge is the problem. I might need a wide body kit I guess. It might look like more in the picture because the wheel is turned out a bit.
Anyone know anything about widebody kits or rolling fenders??
What about: mariahmotorsports mode1
Gregs's Avatar
they will rub, i had some rims with the same amount of tire sticking out and they rubbed when i turned and when i braked, i ended up taking them back cause they fucked my fender up (ive fixed it since)
-greg
Old Dec 10, 2003 | 08:29 PM
Rx7carl's Avatar
Airflow is my life
DONT cut! Use the old NASCAR trick. Baseball bat between the fender lip and the tire. Roll the car and flaten/form the lip to go flat. Be careful as you can wrinkle the fender, so go slow. Also Ive heard the tire rack has a tool they'll loan you to do this, supposed to do a real neat job, call them and ask about it.
Old Dec 10, 2003 | 08:31 PM
gamble302's Avatar
roadkill hats rock
try http://selectmaz.com.au at the bottom of the body kit page
cp racing just came out with some similar to the smaller finder flares too
Old Dec 10, 2003 | 08:32 PM
Thanks carl! I'll contact tire rack and see what they say (I got my tires from them too).
Old Dec 10, 2003 | 08:36 PM
hotty's Avatar
looks like your fuckt up front... I had rub once with less than that sticking out the side, not to mention that in some places having your tires stick out past your fenders is illegal.. hope this doesnt apply to you
Old Dec 10, 2003 | 08:44 PM
I don't understand your first sentence. Do you mean the front looked f-ed up, or it will get f-ed up if I drive the car with the tires sticking out an inch?
You are correct. It is illegal for tires to stick out beyond the fenders, that’s why many cars stock look ridicules, like BMW's (fill those fenders up with rubber!).
My car is already illegal for the street (it's a race car, and I'm not worried about laws and such, because they don't apply to racing on the track or auto-x etc).
Old Dec 10, 2003 | 09:20 PM
Rx7carl's Avatar
Airflow is my life
Well since you bought em from there, you should have no problems borrowing it.
Old Dec 10, 2003 | 09:31 PM
FD Racer's Avatar
sold the FD...kept the FB
i think theres a waiting list to use the fender roller...it tends to be several weeks long as I remember
Old Dec 10, 2003 | 09:47 PM
I guess it must smash the metel thinner and stretch it out? Is that how it works?
Old Dec 10, 2003 | 11:00 PM
FD Racer's Avatar
yeah check it:
http://www.robsaudiworld.com/fender.htm
Old Dec 10, 2003 | 11:36 PM
abeomid's Avatar
Well they will rub as it was said above.
On top of that I would check into the rulebooks b/c last time I checked you are not supposed to have any threads showing if you looks down from the top of the fender in stock and superstock categories. If you are not running that, then it should be fine.
Old Dec 11, 2003 | 12:36 AM
Cody's Avatar
SKELETOR!
Hmm. I'm gonna have to get me some wider wheels, or spacers...
I like the look with them protruding about an inch or so.
Old Dec 11, 2003 | 12:49 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Why not just get a widebody kit?
Old Dec 11, 2003 | 01:00 AM
dirty86's Avatar
GET SOME FATTY FENDERS WHOOO then you can be all bling bling
Old Dec 11, 2003 | 01:44 AM
REVHED's Avatar
Hunting Skylines
All the machine does is flatten the inner lip on the guard. It doesn't actually push the guard out. With the amount your tires are sticking out I doubt it will make any difference.
Old Dec 11, 2003 | 02:46 AM
Gregs's Avatar
cp racings fenderflares would fix your problem nicely
