single turbo vs bnr stage 2s
Old Dec 6, 2003 | 10:42 PM
highspeed101's Avatar
I posted this in 3rd gen but looks like no one knows.
I was wondering which would flow more air at 1 bar. BNR stage 2's with a bored out turbo manifold, running non-seq. or a single with these specs:
.84 ar hot side with 2.53" wheel /64.5mm
.7 ar cold side with 2.38" wheel/60.5mm
P-trim
Thanks
Old Dec 6, 2003 | 11:16 PM
0110-M-P's Avatar
Too Many Projects
I believe the single will flow more air. What turbo are those specs for?
Old Dec 7, 2003 | 12:53 PM
$150FC's Avatar
Currently Winning
so, what, a t04b?
not sure about actual flow but the numbers end up being about the same, especially since you are limiting your top end by going with the .84A/R on the turbine side.
stage ii can get you in the high three hundreds, with that single turbo i don't think you'd pull more than 400rwhp anyway...
cristoDathird
28
May 30, 2019 08:47 PM
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
