Water leak in trunk? Or gas tank sloshing? Foggy windows suck.
Old Nov 30, 2003 | 10:07 PM
Unhappy Water leak in trunk? Or gas tank sloshing? Foggy windows suck.
When I am drifting, hard turning, or going over bumps I hear a sloshing sound in the rear of my car. I cant tell exactly where it is but it's in the rear. After rain, the carpet is damp in my car and the windows are always foggy. Is this a common problem or is my RX not being cooperative? Have you guys had any problems like this? Does your gas tank slosh?
Old Nov 30, 2003 | 10:21 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
Your spare tire well is most likely full of water. The drains in the rear get stopped up and the water goes into the rear area. There is a plug in the tire well that you can pull to let the water out. then clean the drains so It will not happen again.
Old Nov 27, 2004 | 01:02 PM
ChunkyMonkey's Avatar
Clutchless in San Antonio
thanks for the thread, just answered my mystery question as well....1 year old threads rock!...lol...Heard sloshing on my way home today as well.
Old Nov 27, 2004 | 02:24 PM
Rusty Shackleford's Avatar
****ty Tune= Low #'s
where u lift the hatch glass i always have rain in that channel i think the 2 holes on the sides are clogged how can i unclog those??i small stiff gauge wire ??
Old Nov 27, 2004 | 03:12 PM
that's what I read in all the other similar threads. Would a coat hanger work?
Old Nov 27, 2004 | 03:14 PM
iyaseven's Avatar
a wire clothes hanger will do. just be careful not to puncture the rubber tube that drains the water through the holes.
Old Nov 27, 2004 | 04:49 PM
rotor vs. piston's Avatar
Function > Form
I take my tubes of (put down a towel first) and clean the drains in the body with whatever random paint safe solvent I have and then the same with the tubes. Seems to get them cleaner.
Old Nov 27, 2004 | 05:37 PM
DAVID GRIMES's Avatar
How About A Cup Of STFU
The place where the holes are in the channel is a bad place for rust to take hold, too. If you make sure and keep it clear of leaves and **** every time you wash the car, you shouldn't have too much trouble with it.
For clearing the lines, don't forget that compressed air can blast it right out. Do it from the bottom of the hoses and don't have anyone "up top" watching while you do it.
It's been a long time since I discovered that problem and my wheel well was 1/3 full and STINKING, too buddy
Old Nov 27, 2004 | 07:13 PM
I looked at mine today(spare tire) for the first time since I've had it(since may)....No wonder my car would smell after a hot day....Mine was a quarter full...I didn't know there was a drain for the back area, thank god for the FAQ section, lol.....Learning new **** everyday...
alphawolff
Nov 17, 2015 05:57 PM
cam_7779
Aug 18, 2015 07:48 AM
