homemade exhaust flame thrower
I would like to know how to throw flames out of the exhaust with a spark plug, wire, swith. I tried it but had no luck what I did was drill a hole into the last 5in of the exaust and put the spark plug in there and the wire to the positive terminal of the battery. Some one told me that I needed a coil? Please help me
Yea umm here is a few points to help you out. your gunna need a coil for the plug in the exhaust, you SHOULD get another switch to cut power from the origional coils. rev up high, cut power to coils and give power to the other coil and stay on the gas cant go for tooo logn or the car will die. Theres alot more details but those are some of the major points. Do a search!
man i have a stock exhaust and if i get on it on second shift into third at the right rpms.... bam! throwing flames. a small one but a flame... my buddy can light a dark empty highway..
hahaha. you dont need that old school trick you have a 7!!!!!!
umm..unplug your trailing ignitor. accelerate in 3rd gear up to around 6,000rpm, then release the gas...as the car is decelerating in gear..."pop pop pop pop wooooosh pop woosh pop pop wooosh" toasted marshmellows anyone?
