check list for a 85' gsl se..
Old Nov 29, 2003 | 01:31 AM
going to check out the SE tomorrow
am i missing anything, this can be done without mechanics
- check coolant level
- white smoke, warm the car up, hold at 6k and let out the gas right?
- rust / weather stripping
- tires / supension
- engine bay / battery
- seats / interior
- head lights/switches/pop up
- window regulartors (he said it's semi shot already)
- AC?
- power steering?
- idle
- test drive
any other quick and dirty methods? probably can't check for compression (no tools and expertises)
anyone will be in Eagle Rock, CA area, would appreciate it if you'll tag alone (morning, will buy you lunch)
also, anyways you guys thing i should "test" the abovementioned items, pls feel free to let me know.
thanks
TT
Old Nov 29, 2003 | 01:41 AM
hotty's Avatar
sounds good to me.. mine has an oil cooler leak.. I've read that they are quite common.. front left of the car..
Old Nov 29, 2003 | 01:52 AM
Forseti's Avatar
Make sure that the brakes are good and the transmission shifts nicely.
F-
Old Nov 29, 2003 | 02:15 AM
he did mention an oil leak
left as in driver side right?
any quick fix on yours?
Old Nov 29, 2003 | 02:43 AM
hotty's Avatar
I havent done it yet.. I am told that you clean up the area.. and JB weld it, then there are no probs. Its one of my next things on the list.. that and.. I want my friggin windshield washer squirter that a ****** dog chewed off back!
Old Nov 29, 2003 | 03:10 AM
mazdaverx713b's Avatar
Have RX-7, will restore
the oil cooler is VERY prone to leaking, especially if you replace the lines. do not tighten the fittings too tight! trust me, you will regret it!!! i am on my second oil cooler for my se.
Old Nov 29, 2003 | 03:12 AM
how much leak are we talking about?
1/4 or a quart (8 oz) a wk? a month?
oh, and how much oil does it burn? 1 quart/1000 miles?
Old Nov 29, 2003 | 08:56 AM
Northern 7's Avatar
Watch the temp gauge - be sure it's stays down below the 1/2 way marker.
Old Nov 29, 2003 | 09:02 AM
cjf's Avatar
cjf
no way JB weld will hold...if you have a leak in oil cooler, take it off, have it cleaned VERY well and well the neck area. The neck is where the cracks occur...I have mine welded and it still leaks a "bit" but I am ok with it...se oil cooler leaks are common and most of the time, you can weld. however, if not, 400.00 for a new one..There is a "HOW TO BUY A RX7" article by BOB rx7 somewhere out there on the net..maybe some one knows where to find and can tell you...it is great info...good luck with the car if you buy it....cjf
Old Nov 29, 2003 | 10:52 AM
jimmdog's Avatar
Fixed mine with JB a Year ago and I run the **** out of my car no problems
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
